Recognizing that this is basically a FAQ:
nicholas@mordor:~$
nicholas@mordor:~$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
nicholas@mordor:~$
nicholas@mordor:~$ sudo apt autoremove
nicholas@mordor:~$
nicholas@mordor:~$ sudo dpkg --get-selections | grep hold
nicholas@mordor:~$
nicholas@mordor:~$ sudo apt install mariadb-server mariadb-client
The following information may help resolve the situation:
mariadb-server : Depends: mariadb-server-10.3 (>= 1:10.3.25-0ubuntu0.20.04.1) but it is not going to be installed
nicholas@mordor:~$
nicholas@mordor:~$ sudo apt upgrade
Calculating upgrade... Done
nicholas@mordor:~$
nicholas@mordor:~$ sudo apt update
Hit:1 http://ca.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://ca.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://ca.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu focal-security InRelease
All packages are up to date.
nicholas@mordor:~$
nicholas@mordor:~$
but how do I find out what's held or broken?
also:
nicholas@mordor:~$
nicholas@mordor:~$ sudo apt-get install -f
nicholas@mordor:~$
nicholas@mordor:~$ sudo dpkg --configure -a
nicholas@mordor:~$
sources:
nicholas@mordor:~$
nicholas@mordor:~$ cat /etc/apt/sources.list
# deb cdrom:[Ubuntu 20.04 LTS _Focal Fossa_ - Release amd64 (20200423)]/ focal main restricted
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
deb http://ca.archive.ubuntu.com/ubuntu/ focal main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://ca.archive.ubuntu.com/ubuntu/ focal-updates main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://ca.archive.ubuntu.com/ubuntu/ focal universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal universe
deb http://ca.archive.ubuntu.com/ubuntu/ focal-updates universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://ca.archive.ubuntu.com/ubuntu/ focal multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal multiverse
deb http://ca.archive.ubuntu.com/ubuntu/ focal-updates multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://ca.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu focal partner
deb-src http://archive.canonical.com/ubuntu focal partner
deb http://security.ubuntu.com/ubuntu focal-security main restricted
deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://security.ubuntu.com/ubuntu focal-security universe
deb-src http://security.ubuntu.com/ubuntu focal-security universe
deb http://security.ubuntu.com/ubuntu focal-security multiverse
deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
This system was installed using small removable media
(e.g. netinst, live or single CD). The matching "deb cdrom"
entries were disabled at the end of the installation process.
For information about how to configure apt package sources,
see the sources.list(5) manual.
nicholas@mordor:~$
Policy:
nicholas@mordor:~$
nicholas@mordor:~$ apt policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=multiverse,b=amd64
origin security.ubuntu.com
500 http://security.ubuntu.com/ubuntu focal-security/universe i386 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=universe,b=i386
500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://security.ubuntu.com/ubuntu focal-security/restricted i386 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=restricted,b=i386
500 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=restricted,b=amd64
500 http://security.ubuntu.com/ubuntu focal-security/main i386 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=main,b=i386
500 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=main,b=amd64
100 http://ca.archive.ubuntu.com/ubuntu focal-backports/universe i386 Packages
release v=20.04,o=Ubuntu,a=focal-backports,n=focal,l=Ubuntu,c=universe,b=i386
origin ca.archive.ubuntu.com
100 http://ca.archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal-backports,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/multiverse i386 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=multiverse,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=multiverse,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/universe i386 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=universe,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/restricted i386 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=restricted,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=restricted,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/main i386 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=main,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=main,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal/multiverse i386 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=multiverse,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal/multiverse amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=multiverse,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal/universe i386 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=universe,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal/restricted i386 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=restricted,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal/restricted amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=restricted,b=amd64
500 http://ca.archive.ubuntu.com/ubuntu focal/main i386 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=main,b=i386
500 http://ca.archive.ubuntu.com/ubuntu focal/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=main,b=amd64
Pinned packages:
nicholas@mordor:~$
