I recently did a fresh install of Ubuntu 16.04. I also installed mysql-server and mysql-client (their default version 5.7.12) via apt-get install.
Because 5.7.12 was showing some issues, I decided to uninstall it. I tried apt-get remove mysql-server mysql-client first but saw that artifacts like /etc/mysql and /var/lib/mysql didn't get removed.
I then tried apt-get --purge removed mysql-server mysql-client, but still no difference.
So, I manually removed them (via rm -rf). I also manually removed all *mysql* files under /usr/ that came from any mysql-* dependency packages like mysql-common.
However, now, when I wish to re-install mysql-server and -client, I'm finding that I cannot.
In fact, now I'm in a state where I can neither apt-get remove mysql-server nor apt-get install mysql-server!
How do fix the situation I am in? If my local package repository metadata has become corrupted, how do I repair it?
I'd hate to reinstall the whole blessed OS with all my other apps and environment, one more time just because of mysql-server.
The following, for example, is the error I get when I try to remove mysql-server:
$ apt-get remove mysql-server
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libaio1 mysql-client-5.7 mysql-client-core-5.7 mysql-common mysql-server-5.7 mysql-server-core-5.7
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
mysql-server
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 159 kB disk space will be freed.
Do you want to continue? [Y/n]
(Reading database ... 237601 files and directories currently installed.)
Removing mysql-server (5.7.12-0ubuntu1) ...
Setting up mysql-server-5.7 (5.7.12-0ubuntu1) ...
Job for mysql.service failed because the control process exited with error code. See "systemctl status mysql.service" and "journalctl -xe" for details.
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.7 (--configure):
subprocess installed post-installation script returned error exit status 1
mysql-server-5.7
And when trying to install, I get this error:
$ apt-get -f install mysql-server
The following NEW packages will be installed:
mysql-server
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/10.1 kB of archives.
After this operation, 159 kB of additional disk space will be used.
Selecting previously unselected package mysql-server.
(Reading database ... 237599 files and directories currently installed.)
Preparing to unpack .../mysql-server_5.7.12-0ubuntu1_all.deb ...
Unpacking mysql-server (5.7.12-0ubuntu1) ...
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.7; however:
Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
mysql-server-5.7
mysql-server
Here's the output of apt-get install -f :
$ apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
mysql-server-5.7
mysql-server
