39
I am trying to uninstall MySQL completely from Ubuntu 16.04 LTS,but I am facing an issue saying:
mariadb-client-10.0 : Depends: libdbd-mysql-perl (>= 1.2202) but it is not going to be installed
mariadb-client-core-10.0 : Depends: mariadb-common (>= 10.0.24-7) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I tried also to uninstall Mariadb but I have always the same problem. Any idea !!
Hizqeel
  • 1,915
  • 28
  • 24
  • 24
SK7
  • 999
I finally uninstall MySQL completely, and reinstall it using these lines :
Remove all files related to MySQL
sudo apt-get purge mysql*
sudo apt-get autoremove
sudo apt-get autoclean
Then upgrade my distribution
sudo apt-get dist-upgrade
Then install MySQL
sudo apt-get install mysql-server
That's all.
SK7
  • 999
17
As Tico pointed out, if you installed dbconfig-mysql uninstall that first
This worked for me
sudo apt-get remove dbconfig-mysql
after that I could continue with removing mysql-client and mysql-server
David Foerster
  • 36,890
  • 56
  • 97
  • 151
