317
I thought the whole essence of swap was to act as a temporary storage safety net when RAM was full but my swap partition is constantly being used even though I sometimes have as much as 3GB free RAM. Is this normal?
ish
  • 141,990
Mysterio
  • 12,288
6 Answers6
268
You could try changing your "swappiness" value:
From the Ubuntu's Swap FAQ:
What is swappiness and how do I change it?
The swappiness parameter controls the tendency of the kernel to move processes out of physical memory and onto the swap disk. Because disks are much slower than RAM, this can lead to slower response times for system and applications if processes are too aggressively moved out of memory.
  1. swappiness can have a value of between 0 and 100
  2. swappiness=0 tells the kernel to avoid swapping processes out of physical memory for as long as possible. For Kernel version 3.5 and newer it disables swappiness.
  3. swappiness=100 tells the kernel to aggressively swap processes out of physical memory and move them to swap cache
The default setting in Ubuntu is swappiness=60. Reducing the default value of swappiness will probably improve overall performance for a typical Ubuntu desktop installation. A value of swappiness=10 is recommended, but feel free to experiment. Note: Ubuntu server installations have different performance requirements to desktop systems, and the default value of 60 is likely more suitable.
To check the swappiness value
cat /proc/sys/vm/swappiness
To change the swappiness value A temporary change (lost on reboot) with a swappiness value of 10 can be made with
sudo sysctl vm.swappiness=10
To make a change permanent, edit the configuration file with your favorite editor:
gksudo gedit /etc/sysctl.conf
Search for vm.swappiness and change its value as desired. If vm.swappiness does not exist, add it to the end of the file like so:
vm.swappiness=10
Save the file and reboot.
Run sudo sysctl --load=/etc/sysctl.conf after editing the file to apply the changes
Also you can check out: https://askubuntu.com/a/103916/54187
Zanna
  • 72,312
jpetersen
  • 5,629
144
There are a few different aspects to your question.
Firstly, what your definition of "free" is. It is actually not as simple as it sounds in Linux (or any modern operating system).
How Linux uses RAM (very simplified)
Each application can use some of your memory. Linux uses all otherwise unoccupied memory (except for the last few Mb) as "cache". This includes the page cache, inode caches, etc. This is a good thing - it helps speed things up heaps. Both writing to disk and reading from disk can be sped up immensely by cache.
Ideally, you have enough memory for all your applications, and you still have several hundred Mb left for cache. In this situation, as long as your applications don't increase their memory use and the system isn't struggling to get enough space for cache, there is no need for any swap.
Once applications claim more RAM, it simply goes into some of the space that was used by cache, shrinking the cache. De-allocating cache is cheap and easy enough that it is simply done in real time - everything that sits in the cache is either just a second copy of something that's already on disk, so can just be deallocated instantly, or it's something that we would have had to flush to disk within the next few seconds anyway.
This is not a situation that is specific to Linux - all modern operating systems work this way. The different operating systems might just report free RAM differently: some include the cache as part of what they consider "free" and some may not.
When you talk about free RAM, it's a lot more meaningful to include cache, because it practically is free - it's available should any application request it. On Linux, the free command reports it both ways - the first line includes cache in the used RAM column, and the second line includes cache (and buffers) in the free column.
How Linux uses swap (even more simplified)
Once you have used up enough memory that there is not enough left for a smooth-running cache, Linux may decide to re-allocate some unused application memory from RAM to swap.
It doesn't do this according to a definite cut-off. It's not like you reach a certain percentage of allocation then Linux starts swapping. It has a rather "fuzzy" algorithm. It takes a lot of things into account, which can best be described by "how much pressure is there for memory allocation". If there is a lot of "pressure" to allocate new memory, then it will increase the chances some will be swapped to make more room. If there is less "pressure" then it will decrease these chances.
Your system has a "swappiness" setting which helps you tweak how this "pressure" is calculated. It's normally not recommended to alter this at all, and I would not recommend you alter it. Swapping is overall a very good thing - although there are a few edge cases where it harms performance, if you look at overall system performance it's a net benefit for a wide range of tasks. If you reduce the swappiness, you let the amount of cache memory shrink a little bit more than it would otherwise, even when it may really be useful. Whether this is a good enough trade-off for whatever problem you're having with swapping is up to you. You should just know what you're doing, that's all.
There is a well-known situation in which swap really harms perceived performance on a desktop system, and that's in how quickly applications can respond to user input again after being left idle for a long time and having background processes heavy in IO (such as an overnight backup) run. This is a very visible sluggishness, but not enough to justify turning off swap all together and very hard to prevent in any operating system. Turn off swap and this initial sluggishness after the backup/virus scan may not happen, but the system may run a little bit slower all day long. This is not a situation that's limited to Linux, either.
When choosing what is to be swapped to disk, the system tries to pick memory that is not actually being used - read to or written from. It has a pretty simple algorithm for calculating this that chooses well most of the time.
If you have a system where you have a huge amount of RAM (at time of writing, 8GB is a huge amount for a typical Linux distro), then you will very rarely ever hit a situation where swap is needed at all. You may even try turning swap off. I never recommend doing that, but only because you never know when more RAM may save you from some application crashing. But if you know you're not going to need it, you can do it.
But how can swap speed up my system? Doesn't swapping slow things down?
The act of transferring data from RAM to swap is a slow operation, but it's only taken when the kernel is pretty sure the overall benefit will outweigh this. For example, if your application memory has risen to the point that you have almost no cache left and your I/O is very inefficient because of this, you can actually get a lot more speed out of your system by freeing up some memory, even after the initial expense of swapping data in order to free it up.
It's also a last resort should your applications actually request more memory than you actually have. In this case, swapping is necessary to prevent an out-of-memory situation which will often result in an application crashing or having to be forcibly killed.
Swapping is only associated with times where your system is performing poorly because it happens at times when you are running out of usable RAM, which would slow your system down (or make it unstable) even if you didn't have swap. So to simplify things, swapping happens because your system is becoming bogged down, rather than the other way around.
Once data is in swap, when does it come out again?
Transferring data out of swap is (for traditional hard disks, at least) just as time-consuming as putting it in there. So understandably, your kernel will be just as reluctant to remove data from swap, especially if it's not actually being used (ie read from or written to). If you have data in swap and it's not being used, then it's actually a good thing that it remains in swap, since it leaves more memory for other things that are being used, potentially speeding up your system.
thomasrutter
  • 37,804
36
Setting the swappiness value doesn't work in every situation. If it works for you, great. If not, I've written a script to periodically clear out swap by turning it off and back on again.
Toggling swap is a bit risky if you're not careful. If you don't have enough free RAM to hold everything in RAM plus everything in swap, trying to disable swap will cause your system to become unresponsive. My script first checks whether there's enough free RAM (which takes a bit of doing, as the actual amount of free RAM is different from what free reports as free), then only toggles swap if so. But, if you're a bit short on RAM, don't start another major process while the script is running. Here it is:
#!/bin/bash
# Make sure that all text is parsed in the same language
export LC_MESSAGES=en_US.UTF-8
export LC_COLLATE=en_US.UTF-8
export LANG=en_US.utf8
export LANGUAGE=en_US:en
export LC_CTYPE=en_US.UTF-8
# Calculate how much memory and swap is free
free_data="$(free)"
mem_data="$(echo "$free_data" | grep 'Mem:')"
free_mem="$(echo "$mem_data" | awk '{print $4}')"
buffers="$(echo "$mem_data" | awk '{print $6}')"
cache="$(echo "$mem_data" | awk '{print $7}')"
total_free=$((free_mem + buffers + cache))
used_swap="$(echo "$free_data" | grep 'Swap:' | awk '{print $3}')"
echo -e "Free memory:\t$total_free kB ($((total_free / 1024)) MB)\nUsed swap:\t$used_swap kB ($((used_swap / 1024)) MB)"
# Do the work
if [[ $used_swap -eq 0 ]]; then
    echo "Congratulations! No swap is in use."
elif [[ $used_swap -lt $total_free ]]; then
    echo "Freeing swap..."
    swapoff -a
    swapon -a
else
    echo "Not enough free memory. Exiting."
    exit 1
fi
You must run this script as root (e.g., with sudo). This script won't leave your system unresponsive; if you've got insufficient RAM, it will refuse to toggle swap. I've used this script without problems for close to five years now.
Eliah Kagan
  • 119,640
12
I edited the script of Scott Severance to match the newer versions of free which already include a total available memory field.
#!/bin/bash
free_mem="$(free | grep 'Mem:' | awk '{print $7}')"
used_swap="$(free | grep 'Swap:' | awk '{print $3}')"
echo -e "Free memory:\t$free_mem kB ($((free_mem / 1024)) MiB)\nUsed swap:\t$used_swap kB ($((used_swap / 1024)) MiB)"
elif [[ $used_swap -lt $free_mem ]]; then
    sudo swapoff -a
    sudo swapon -a
else
    exit 1
fi
Eliah Kagan
  • 119,640
Generally swap remains unused on now-a-days systems. In my experience, the processes which are running for a long time without intensive operations are shifted to swap by the linux.
It makes a few affected programs run slow.
If you have lots of ram free, you may switch the swap off by running the command:
swapoff -av (you'll need sudo rights for it.)
If you don't like the swap off, you may switch it on, using symmetrical command:
swapon -av (again sudo required).
drake01
  • 3,515
Once swap has been used for a program it tends to remain mapped for the life of the program. Many programs have code (and data) which is rarely used. Once the memory is swapped out, it is unlikely to be swapped in.
One way to force these pages into memory is to turn off the swap device. If you have two, you can turn one off, turn it back on, then turn off the second one. If swap is really needed, it will move between devices. You could just turn off the swap device (or file), but if you really need swap space drastic things can happen.
Besides the normal things in memory, tmpfs uses swap space, and will swap out like the rest of memory. If you run something that requires a lot of temp disk, it may force pages to be swapped out. Once created temp files may no longer be used after a couple of minutes and are good candidates to be moved to the swap device.
In a pinch you can use a file as a swap device. This is useful if you need extra swap space temporarily.
Alexis Wilke
  • 2,787
BillThor
  • 4,698
