I'm using Ubuntu 16.04 on a USB drive with persistent flag.
(Yes, I need this as I need to move around with it and use on various computers.)
Most recently I've used this on a Dual Xeon server box with 64Gb of RAM, so I can rule out CPU or RAM as an issue, and it is very very slow:
For example, clicking on Chrome to open the browser may take 30-60sec, once Chrome is open, loading a page in a tab that was previously open takes another 30-60sec. Often times I get the 'window is unresponsive' shadowed window warning.
Command line / Terminal commands is fairly responsive, but it seems that as soon as some sort of GUI or display terminal needs to open, it takes forever, which makes me wonder if it is related to graphics hardware.
The USB drive is 32GB, admittedly Ubuntu is only on a 4GB partition which was the max I could allocate, but there is still quite some room.
I understand USB 2.0 is slower than SATA2 by ~10x, but here I feel like this is way more than a 10x slow down, plus that could account for loading time, but once loaded there should not but such issues.
I also realize this is a broad question, but where do I start to troubleshoot this sluggishness?
Could someone recommend steps to check different parts of the system that could cause this type of issues?
Thanks
EDIT: I mostly use command line on this OS (to compile and test stuff), but I often need to refer to doc online, which is why I opted for the Desktop version and need Chrome)
