If you have already made a swap file during setup of ubuntu, would the commands mkswap and swapon add to it or it replaces it? Is there a way to add to it rather than replace it? Is there a way to do it while you are not sudoer?
You can
  • create a partition and make it a swap partition with mkswap or gparted
  • add a corresponding line in the file /etc/fstab to make it active at boot. You can use
    sudo swapon -a
    to make all swap devices (files and partitions in /etc/fstab) active.
  • You can also create a second swapfile (with another name), or maybe better, replace the current swapfile with a new one.
But first you should consider, if you really need more swap and in that case why and how much.
Managing swap is a typical task, where you need sudo permissions.
sudodus
  • 47,684
The command swapon <specialfile> adds a swap area prepared with mkswap <device>.
swapon --show displays the active swap areas.
muclux
  • 5,324
