73
TL;DR
Recently, during the normal software upgrade process (i.e., apt upgrade or apt dist-upgrade) I started getting messages like this:
The following packages have been kept back:
0 upgraded, 0 newly installed, 0 to remove and [...] not upgraded.
What are my options?
Note: This is not a duplicate of the myriad similar questions asked already here. You should consider my question as a follow-up to this question.
I had exactly the same problem on my main Ubuntu 22.04 system as the question mentioned above. I changed servers, tried to manually install the named package, and somehow the problem was solved, yesterday. Today, when I tried to install any new updates, I got the message that I had 32 packages that have been kept back.
I have a similar 22.04 version (virtual) Ubuntu installation, which is fully updated now and this problem does not yet occur there (with a similar /etc/apt/sources.list file). So, I tried to compare the packages. I took the package gir1.2-gstreamer-1.0 which was "kept back" in my main system as an example and ran on my main system:
$ sudo apt --installed list | grep gir1.2-gstreamer-1.0
gir1.2-gstreamer-1.0/jammy,now 1.20.1-1 amd64 [installed,upgradable to: 1.20.3-0ubuntu1]
The same command gives the output:
gir1.2-gstreamer-1.0/jammy,now 1.20.1-1 amd64 [installed,automatic]
on my secondary (virtual) system.
Why do we have this difference? And, how can I make my main system behave as the (virtual) system where the package is installed "automatic"ally?
The output of the command apt-cache policy gir1.2-gstreamer-1.0 on my "main" system is like this:
gir1.2-gstreamer-1.0:
  Installed: 1.20.1-1
  Candidate: 1.20.3-0ubuntu1
  Version table:
     1.20.3-0ubuntu1 500 (phased 30%)
        500 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
 *** 1.20.1-1 500
        500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages
        100 /var/lib/dpkg/status
And on my "secondary" (virtual) system is like this:
  Installed: 1.20.1-1
  Candidate: 1.20.1-1
  Version table:
     1.20.3-0ubuntu1 1 (phased 30%)
 *** 1.20.1-1 500
What does the value 500 (in the (phased... line) mean?
On both systems grep -ri phased /etc/apt returns nothing.
After the command sudo apt update && sudo apt upgrade gir1.2-gstreamer-1.0 was executed on my main system:
gir1.2-gstreamer-1.0/jammy-updates,now 1.20.3-0ubuntu1 amd64 [installed]
$ apt-cache policy gir1.2-gstreamer-1.0 gir1.2-gstreamer-1.0: Installed: 1.20.3-0ubuntu1 Candidate: 1.20.3-0ubuntu1 Version table: *** 1.20.3-0ubuntu1 500 (phased 40%) 500 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages 100 /var/lib/dpkg/status 1.20.1-1 500 500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages
Now, on my secondary system I started getting this too:
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
  language-pack-gnome-en
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
FedKad
  • 13,420
Phased Updates are a safety feature
  • Some users get the upgraded packages first, and have the ability to report broken package, instead of everybody getting a broken package at once and millions of users scratching their heads.
It's there for your protection. Don't try to outsmart it.
  • Kept-back packages due to Phased Updates will automatically resolve themselves, download, and install over a week or so.
Most users should DO NOTHING. It's not broken. Don't try to force upgrades. Just be patient and let the system work.
Diagnosis -- how to tell if Phased Updates is the culprit:
  • It's easy. Run apt-cache policy <packagename> on one of your held back packages. Look for the 'phased' percentage. It's only present if the package is currently phasing.
  Version table:
 *** 1.20.3-0ubuntu1 500 (phased 40%) <----------------- There it is!
     1.20.1-1 500
Advanced usage
  • Phased Updates can be disabled -- it's a simple apt setting, but keep in mind that you're disabling a feature that protects you from receiving broken packages. YOU are offering to test those packages!
  • Users with multiple machines can set the machines to phase together -- it's just another simple apt setting.
Example of how to skip phasing one time:
apt -o APT::Get::Always-Include-Phased-Updates=true upgrade
Example of how to skip phasing permanently using an apt config file (NOT recommended for most users)
cat <<EOF > /etc/apt/apt.conf.d/80PhasedUpdates
// Enable/Disable phased updates
// Default is Phased Updates enabled. Use these lines to disable.
APT::Get::Never-Include-Phased-Updates: True;
Update-Manager::Never-Include-Phased-Updates;
EOF
Example of how to sync phasing of a group of machines using an identical apt config file on each machine:
// To have multiple your machines phase the same, set the same
//   string in this field on all those machines
// If commented out or missing, apt will use /etc/machine-id to
//   seed the random number generator
APT::Machine-ID "aaaabbbbccccddddeeeeffff";
EOF
Also see What `apt` configuration file should the Never-Include-Phased-Updates flag be placed in?
user535733
  • 68,493
21
It is certainly possible the difference is the Phased updates system. See if the packages behave the same on both machines if you run this command on both machines.
cat <<EOF > /etc/apt/apt.conf.d/80my
APT::Get::Always-Include-Phased-Updates "1";
EOF
More background on phased updates
Phased updates in APT in 21.04
APT now implements phased updates. Previously, only update-manager implemented phased updates ...
This means that some updates will be hold back on some machines while they are being phased. This is being decided by a value derived from the machine-id, the package name, and package version.
Manpage for apt_preferences
APT understands a field called Phased-Update-Percentage which can be used to control the rollout of a new version. It is an integer between 0 and 100.
In case you have multiple systems that you want to receive the same set of updates, you can set APT::Machine-ID to a UUID such that they all phase the same, or set APT::Get::Never-Include-Phased-Updates or APT::Get::Always-Include-Phased-Updates to true such that APT will never/always consider phased updates.
The manpage also indicates versions that are "not phased" will get priority 1, which matches your apt-cache policy output.
The following method was useful for me:
sudo apt install --only-upgrade <package_name>
From manual:
--only-upgrade Do not install new packages; when used in conjunction with install, only-upgrade will install upgrades for already installed packages only and ignore requests to install new packages.
Configuration Item: APT::Get::Only-Upgrade.
See also: https://itsfoss.com/following-packages-have-been-kept-back/
Pablo Bianchi
  • 17,371
