I am fairly new to Ubuntu
My system has been failing to upgrade to 23.04 since it came out.
Instructions are:
  • Install ALL pending software updates
  • then upgrade
Unfortunately,
sudo apt full-upgrade
ends with the following message:
The following packages have been kept back:
(Package details deliberately omitted.)
0 to upgrade, 0 to newly install, 0 to remove and 4 not to upgrade.
I can see more details as expected with:
apt list --upgradable
In answer to the question whether to force the update: How to force "packages [that] have been kept back" to be installed [as] "automatic"?
The general gist was don't and wait for a fix. So how can I upgrade with out forcing the issue?
sudo do-release-upgrade
Fails as expected with:
Please install all available updates for your release before upgrading.
How can/should I get these packages to update? or do I need to delete them and their dependencies? That could be quite painful.
Or do I just carry on waiting?
First, determine the reason why the packages are kept back.
There are two main possibilities: Phased Updates or Version Conflict
Phased updates are easy to spot and phasing can be easily skipped so you can release-upgrade:
$ sudo apt update
$ apt policy foo [...] Version table: *** 1.1.1 500 (phasing=50%) <------------- This package is phasing [...]
// One-time (not permanent) way to immediately install Phased Updates. $ sudo apt -o APT::Get::Always-Include-Phased-Updates=true upgrade
Version conflicts look more like this: Multiple versions from multiple sources. Each version conflict must be solved or fixed before a release-upgrade is possible. Happily, they are usually not difficult.
$ sudo apt update
$ apt policy foo foo: Installed: 1.2 Candidate: 1.2 Version table: *** 1.1 500 500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages 1.2 500 500 http://someplace-else.org/ stable amd64 Packages <--- The Problem 100 /var/lib/dpkg/status
// Revert to the compatible Ubuntu package by specifying the version $ sudo apt install foo=1.1
// Delete or disable the source that provides the conflicting package(s) $ sudo apt edit-sources
// Since your sources just changed: $ sudo apt update
user535733
  • 68,493
