I got a partial update dialog today while running an update check and decided to check on the command line before doing so first.
I then decided to run dist-upgrade and got 30 packages I can remove, but I am not sure why all of a sudden I can remove them today. I use disk encryption and for example libcryptsetup12 is marked to be removed. Others are like php80-zip altough I still use this version and module daily via apache2.
How can I make sure that this autoremove run won't break my system?
Edit This is the output of sudo apt-get autoremove:
Die folgenden Pakete werden ENTFERNT:
  libapparmor1:i386 libappindicator1 libargon2-1:i386 libcap2:i386 libcryptsetup12:i386 libdevmapper1.02.1:i386 libffi7:i386 libfwupdplugin1 libgmp10:i386 libgnutls30:i386 libhogweed5:i386 libip4tc2:i386
  libjs-openlayers libjson-c4:i386 libkmod2:i386 libllvm11 libnettle7:i386 libp11-kit0:i386 libqt5sensors5 libqt5webkit5 libseccomp2:i386 libssl1.1:i386 libtasn1-6:i386 php8.0-gd php8.0-ssh2 php8.0-zip
  qml-module-qtquick-controls qml-module-qtquick-dialogs qml-module-qtquick-privatewidgets shim
Update: I also have a few held pack packages as of now, including the newest kernel.
libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev linux-generic linux-headers-generic linux-image-generic
Update, this is the output of dist-upgrade right now
sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libapparmor1:i386 libappindicator1 libargon2-1:i386 libcap2:i386 libffi7:i386 libfwupdplugin1 libgmp10:i386 libgnutls30:i386 libhogweed5:i386 libip4tc2:i386 libjs-openlayers libjson-c4:i386
  libkmod2:i386 libllvm11 libnettle7:i386 libp11-kit0:i386 libqt5sensors5 libqt5webkit5 libseccomp2:i386 libssl1.1:i386 libtasn1-6:i386 php8.0-gd php8.0-ssh2 php8.0-zip qml-module-qtquick-controls
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  libcryptsetup12:i386 libdevmapper1.02.1:i386 libmount1:i386 libpcre2-8-0:i386 libpcre2-posix2 libselinux1:i386
The following NEW packages will be installed:
  libpcre2-posix3 linux-headers-5.4.0-107 linux-headers-5.4.0-107-generic linux-image-5.4.0-107-generic linux-modules-5.4.0-107-generic linux-modules-extra-5.4.0-107-generic
The following packages will be upgraded:
  libnetplan0 libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev linux-generic linux-headers-generic linux-image-generic linux-libc-dev netplan.io
10 upgraded, 6 newly installed, 6 to remove and 0 not upgraded.
Need to get 79.7 MB of archives.
After this operation, 378 MB of additional disk space will be used.
Edit: I found that an external PPA was triggering the witholding of packages hence the partial update warning. If the external PPA is deactivated, everything goes back to normal. I have contacted the author of that PPA to find out more and will close this now.
