I have fairly recent (~3-4 weeks) Kubuntu installation (clean, not an upgrade).
Today I discovered that attempting to upgrade the system reports 50 packages that have been kept back:
user@machine:~$ sudo apt update
Hit:1 https://swupdate.openvpn.net/community/openvpn3/repos jammy InRelease
Hit:2 http://ro.archive.ubuntu.com/ubuntu jammy InRelease
Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:4 http://ro.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:5 http://ro.archive.ubuntu.com/ubuntu jammy-backports InRelease
Reading package lists... Done
Building dependency tree... Done
50 packages can be upgraded. Run 'apt list --upgradable' to see them.
user@machine:~$ sudo apt upgrade
Calculating upgrade... Done
The following packages have been kept back:
kde-config-sddm kde-config-updates kde-style-oxygen-qt5 kinfocenter ksystemstats kwin-common kwin-data kwin-x11 layer-shell-qt libcolorcorrect5 libkf5sysguard-data libkfontinst5 libkfontinstui5 libksgrd9
libksysguardformatter1 libksysguardsensorfaces1 libksysguardsensors1 libksysguardsystemstats1 libkwaylandserver5 libkwineffects13 libkwinglutils13 libkwinxrenderutils13 libkworkspace5-5 liblayershellqtinterface5
libnotificationmanager1 liboxygenstyle5-5 liboxygenstyleconfig5-5 libplasma-geolocation-interface5 libprocesscore9 libprocessui9 libtaskmanager6 libweather-ion7 milou oxygen-sounds php8.1-cli php8.1-common php8.1-opcache
php8.1-readline plasma-desktop plasma-desktop-data plasma-discover plasma-discover-backend-fwupd plasma-discover-backend-snap plasma-discover-common plasma-nm plasma-pa plasma-workspace qml-module-org-kde-ksysguard
systemsettings xdg-desktop-portal-kde
0 upgraded, 0 newly installed, 0 to remove and 50 not upgraded.
I have received the packages have been kept back message two times since the OS was installed, but it listed one or two packages and I solved the issue with:
sudo apt upgrade package1 package2 ...
However, this time there seems to be a dependency error:
user@machine:~$ sudo apt upgrade systemsettings
plasma-workspace : Depends: libkworkspace5-5 (= 4:5.24.4-0ubuntu1) but 4:5.24.6-0ubuntu0.1 is to be installed
E: Broken packages
What I have tried:
apt updateapt install -fapt cleanrm /var/cache/apt/archives/*.deb && rm -R /var/cache/apt/archives/partialapt upgrade --fix-missingapt upgrade --fix-brokenapt --fix-broken install
... and probably one or two more.
What is the cause of it and how can I do to fix this issue?
Later edit #1:
Output of policy for plasma-workspace:
apt-cache policy plasma-workspace
plasma-workspace:
Installed: 4:5.24.4-0ubuntu1
Candidate: 4:5.24.6-0ubuntu0.1
Version table:
4:5.24.6-0ubuntu0.1 500 (phased 10%)
500 http://ro.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
*** 4:5.24.4-0ubuntu1 500
500 http://ro.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
100 /var/lib/dpkg/status
Later edit #2:
As noted in the accepted answer, this delayed upgrade is intentional and normal - and two days after posting the question, all packages successfully upgraded on my system.
