I've tried to sudo update and upgrade as usual but it displays
The following packages have been kept back:
base-files python3-distupgrade python3-gi python3-gi-cairo
ubuntu-release-upgrader-core ubuntu-release-upgrader-gtk
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
I've tried:
- the normal procedure (sudo apt update and upgrade)
- the apt-get procedure
- sudo -i and performed the normal procedure -https://www.youtube.com/watch?v=Il_Za-wlW5I (whats in this video)
- changing software updater and software and updates settings
(also tried restarting my laptop)
Before I tried mounting an usb and a sd card. While I tried this I didn't have a net connection at the time. I tried updating and of course it didn't work. After noticing and reconnecting I did install some updates but then it got stuck on that display
Full display: sudo apt update
[sudo] password for dcg:
Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
Reading package lists... Done
Building dependency tree... Done
6 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Target Sources (restricted/source/Sources) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list:7
dcg@dcg-IdeaPad-5-15ITL05:~$ sudo apt upgrade
Calculating upgrade... Done
List of updates:
cg@dcg-IdeaPad-5-15ITL05:~$ apt list --upgradable
Listing... Done
base-files/jammy-updates 12ubuntu4.2 amd64 [upgradable from: 12ubuntu4.1]
python3-distupgrade/jammy-updates,jammy-updates 1:22.04.12 all [upgradable from: 1:22.04.11]
python3-gi-cairo/jammy-updates 3.42.1-0ubuntu1 amd64 [upgradable from: 3.42.0-3build1]
python3-gi/jammy-updates 3.42.1-0ubuntu1 amd64 [upgradable from: 3.42.0-3build1]
ubuntu-release-upgrader-core/jammy-updates,jammy-updates 1:22.04.12 all [upgradable from: 1:22.04.11]
ubuntu-release-upgrader-gtk/jammy-updates,jammy-updates 1:22.04.12 all [upgradable from: 1:22.04.11]
dcg@dcg-IdeaPad-5-15ITL05:~$ sudo apt update
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [99,8 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main i386 Packages [260 kB]
Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [474 kB]
Get:7 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [196 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy-updates/universe i386 Packages [102 kB]
Fetched 1356 kB in 4s (386 kB/s)
dcg@dcg-IdeaPad-5-15ITL05:~$ sudo apt full-upgrade
base-files python3-distupgrade ubuntu-release-upgrader-core
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Need to get 237 kB of archives.
After this operation, 1024 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-gi-cairo amd64 3.42.1-0ubuntu1 [8184 B]
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-gi amd64 3.42.1-0ubuntu1 [229 kB]
Fetched 237 kB in 1s (410 kB/s)
(Reading database ... 215354 files and directories currently installed.)
Preparing to unpack .../python3-gi-cairo_3.42.1-0ubuntu1_amd64.deb ...
Unpacking python3-gi-cairo (3.42.1-0ubuntu1) over (3.42.0-3build1) ...
Preparing to unpack .../python3-gi_3.42.1-0ubuntu1_amd64.deb ...
Unpacking python3-gi (3.42.1-0ubuntu1) over (3.42.0-3build1) ...
Setting up python3-gi (3.42.1-0ubuntu1) ...
Setting up python3-gi-cairo (3.42.1-0ubuntu1) ...
(From here on out only 4 packages were not upgraded...I don't know how the other 2 upgraded)
Using sudo apt full-update:
