The GUI just finishes when I press the "Upgrade..." button. Very impolitely. I then tried the command line and got:
$ sudo apt upgrade
The following packages have been kept back:
  linux-modules-nvidia-535-6.2.0-39-generic linux-modules-nvidia-535-generic-hwe-22.04 linux-objects-nvidia-535-6.2.0-39-generic
  linux-signatures-nvidia-6.2.0-39-generic
0 to upgrade, 0 to newly install, 0 to remove and 4 not to upgrade.
$ sudo do-release-upgrade
Checking for a new Ubuntu release
Your Ubuntu release is not supported anymore.
For upgrade information, please visit:
http://www.ubuntu.com/releaseendoflife
Please install all available updates for your release before upgrading.
How to proceed? May I force the distribution upgrade? Or can I force the package update? Or can I tell the machine to ignore the kept back packages? And why am I the only one who has this problem?
Addendum: The reinstall method does not work:
$ sudo apt reinstall linux-modules-nvidia-535-6.2.0-39-generic linux-modules-nvidia-535-generic-hwe-22.04 linux-objects-nvidia-535-6.2.0-39-generic linux-signatures-nvidia-6.2.0-39-generic
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies. linux-modules-nvidia-535-6.2.0-39-generic : Depends: nvidia-kernel-common-535 (>= 535.154.05) but 535.146.02-0ubuntu0.23.04.1 is to be installed linux-modules-nvidia-535-generic-hwe-22.04 : Depends: nvidia-kernel-common-535 (>= 535.154.05) but 535.146.02-0ubuntu0.23.04.1 is to be installed E: Unable to correct problems, you have held broken packages.
Addendum II: This one (from the linked issue) might have worked, at least I am now starting the upgrade:
sudo apt install --only-upgrade linux-signatures-nvidia-6.2.0-39-generic
This removed the packages linux-modules-nvidia-530-generic-hwe-22.04 linux-modules-nvidia-535-6.2.0-39-generic linux-modules-nvidia-535-generic-hwe-22.04. Afterwards apt dist-upgrade upgraded linux-objects-nvidia-535-6.2.0-39-generic.
Finally I am rather confused about that mechanism, but am going to start the upgrade process now, via do-release-upgrade.
