When trying to install WINE (sudo apt-get install wine) I get the following error:
wine : Depends: wine1.5 but it is not going to be installed
Google does tell me that apparently this has something to to with ia32-libs, but I cannot find out how to do to fix the dependencies or if I need to (manually?) install something else.
I have added ppa:ubuntu-wine/ppa to my repositories.
sudo apt-get install wine1.5gives me
wine1.5 : Depends: wine1.5-i386 (= 1.5.4-0ubuntu1~ppa1~precise1+pulse17)
sudo apt-get install wine1.5-i386gives me
wine1.5-i386:i386 : Depends: libgphoto2-2:i386 (>= 2.4.10.1) but it is not going to be installed
Depends: libgphoto2-port0:i386 (>= 2.4.10.1) but it is not going to be installed
Recommends: gettext:i386 but it is not going to be installed
Recommends: libsane:i386 but it is not going to be installed
Any help would be appreciated. Thanks.
