I can't install WINE. When I go to the terminal and type sudo apt-get install wine1.7, I get
Reading package lists... Done
Building dependency tree
 wine1.7 : Depends: wine1.7-i386 (= 1:1.7.12-0ubuntu1~saucy1)
           Recommends: winbind
I've looked around here on AskUbuntu, and haven't found a solution to the problem. I tried going into Synaptic and going to Edit --> Fix Broken Packages, but this doesn't fix the problem. I've tried sudo apt-get autoremove and sudo apt-get update, but those do not solve the issue either. I've tried adding the WINE PPA, but that doesn't work either.
This issue started after trying to install netflix-desktop from the ppa:ehoover/compholio PPA. After I installed this, an icon appeared in my panel telling me of a problem involving wine1.7:i386 not being in the cache. I had this problem once before, so I uninstalled WINE and removed the PPA, but now WINE won't install at all.
Any ideas?
Braiam
  • 69,112
