I am a pretty novice user and have just recently installed Ubuntu 12.10 on my six year-old laptop as a dual boot with Windows. I installed with the simple Windows Installer and haven't done any major adjustments to Ubuntu other than to install the beta of Google Music Uploader for Ubuntu.
I just recently tried to use get Wine so I can run EAC (Exact Audio Copy). However, whenever I run the command in the terminal to get Wine 1.5, I errors.
For example, if I out in this command: "sudo apt-get install wine"
I get this:
"Reading package lists... Done
Building dependency tree
wine : Depends: wine1.5 but it is not going to be installed
E: Unable to correct problems, you have held broken packages."
When I input this "sudo apt-get install wine1.5" I get this:
wine1.5 : Depends: wine1.5-i386 (= 1.5.25-0ubuntu1) but it is not installable
Recommends: gnome-exe-thumbnailer but it is not going to be installed or
kde-runtime but it is not going to be installed
Recommends: fonts-droid but it is not going to be installed
Recommends: ttf-mscorefonts-installer but it is not going to be installed
Recommends: fonts-horai-umefont but it is not going to be installed
Recommends: fonts-unfonts-core but it is not going to be installed
Recommends: winbind but it is not going to be installed
Recommends: winetricks but it is not going to be installed
Before this I tried the same with Wine1.4. Same error messages.
Any ideas? I'm pretty new to Ubuntu and the open-source world, so any help would be greatly appreciated. Thanks.
