Trying user1261084 solution:
$ sudo apt-get install wine
Reading package lists... Done
Building dependency tree
wine : Depends: wine1.4 but it is not going to be installed
Trying @eric-carvalho solution once more
$ apt-cache policy libgnutls26
libgnutls26:
Installed: 2.12.19-1
Candidate: 2.12.19-1
Version table:
*** 2.12.19-1 0
100 /var/lib/dpkg/status
2.12.14-5ubuntu3.1 0
500 http://archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
2.12.14-5ubuntu3 0
500 http://archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
I was removed ppa:ubuntu-wine/ppa repository (Software Center > Edit > Software Sources > Other Software and manually remove) then went to Ubuntu Software tab and changed Download from to Main Server as user1261084 suggested.
after that I tried to downgrade libgnutls26 to version 2.12.14-5ubuntu3.1:
$ sudo apt-get install libgnutls26=2.12.14-5ubuntu3.1
Suggested packages:
gnutls-bin
The following packages will be DOWNGRADED:
libgnutls26
0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 8 not upgraded.
Need to get 459 kB of archives.
After this operation, 326 kB disk space will be freed.
Do you want to continue [Y/n]? Y
Get:1 http://archive.ubuntu.com/ubuntu/ precise-updates/main libgnutls26 amd64 2.12.14-5ubuntu3.1 [459 kB]
Fetched 459 kB in 5s (86.8 kB/s)
dpkg: warning: downgrading libgnutls26 from 2.12.19-1 to 2.12.14-5ubuntu3.1.
(Reading database ... 267654 files and directories currently installed.)
Preparing to replace libgnutls26 2.12.19-1 (using .../libgnutls26_2.12.14-5ubuntu3.1_amd64.deb) ...
Unpacking replacement libgnutls26 ...
Setting up libgnutls26 (2.12.14-5ubuntu3.1) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
it worked so:
The following packages were automatically installed and are no longer required:
autopoint rpm librpmbuild2 librpmsign0
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
fonts-droid fonts-horai-umefont libasn1-8-heimdal:i386 libavahi-client3:i386 libavahi-common-data:i386 libavahi-common3:i386 libcapi20-3
libcapi20-3:i386 libcups2:i386 libexif12:i386 libgcrypt11:i386 libgd2-xpm:i386 libgif4:i386 libgl1-mesa-dri:i386 libgl1-mesa-glx:i386
libglapi-mesa:i386 libglu1-mesa:i386 libgnutls26:i386 libgpg-error0:i386 libgphoto2-2:i386 libgphoto2-port0:i386 libgssapi-krb5-2:i386
libgssapi3-heimdal:i386 libgstreamer-plugins-base0.10-0:i386 libgstreamer0.10-0:i386 libhcrypto4-heimdal:i386 libheimbase1-heimdal:i386
libheimntlm0-heimdal:i386 libhx509-5-heimdal:i386 libieee1284-3:i386 libk5crypto3:i386 libkeyutils1:i386 libkrb5-26-heimdal:i386 libkrb5-3:i386
libkrb5support0:i386 libldap-2.4-2:i386 libllvm3.0:i386 libltdl7:i386 libmpg123-0:i386 libopenal1:i386 liborc-0.4-0:i386 libp11-kit0:i386
libroken18-heimdal:i386 libsane:i386 libsasl2-2:i386 libsasl2-modules:i386 libssl1.0.0:i386 libtasn1-3:i386 libusb-0.1-4:i386 libv4l-0:i386
libv4lconvert0:i386 libwind0-heimdal:i386 libx11-xcb1:i386 libxcb-glx0:i386 libxcomposite1:i386 libxcursor1:i386 libxdamage1:i386 libxfixes3:i386
libxinerama1:i386 libxml2:i386 libxpm4:i386 libxrandr2:i386 libxslt1.1:i386 libxxf86vm1:i386 ttf-droid ttf-umefont wine-gecko1.4 wine-gecko1.4:i386
wine1.4 wine1.4-amd64 wine1.4-common wine1.4-i386:i386 winetricks
Suggested packages:
cups-common:i386 rng-tools:i386 libgd-tools:i386 libglide3:i386 gnutls-bin:i386 gphoto2:i386 gtkam:i386 krb5-doc:i386 krb5-user:i386
libvisual-0.4-plugins:i386 gstreamer-codec-install:i386 gnome-codec-install:i386 gstreamer0.10-tools:i386 gstreamer0.10-plugins-base:i386 hpoj:i386
hplip:i386 libsane-extras:i386 sane-utils:i386 libsasl2-modules-otp:i386 libsasl2-modules-ldap:i386 libsasl2-modules-sql:i386
libsasl2-modules-gssapi-mit:i386 libsasl2-modules-gssapi-heimdal:i386 dosbox
Recommended packages:
xml-core:i386 gettext:i386
The following packages will be REMOVED:
alien debhelper gettext gnome-common intltool intltool-debian po-debconf
The following NEW packages will be installed:
libxinerama1:i386 libxml2:i386 libxpm4:i386 libxrandr2:i386 libxslt1.1:i386 libxxf86vm1:i386 ttf-droid ttf-umefont wine wine-gecko1.4
wine-gecko1.4:i386 wine1.4 wine1.4-amd64 wine1.4-common wine1.4-i386:i386 winetricks
0 upgraded, 74 newly installed, 7 to remove and 8 not upgraded.
Need to get 143 MB of archives.
After this operation, 408 MB of additional disk space will be used.
Setting up wine1.4-common (1.4-0ubuntu4.1) ...
Setting up wine1.4-amd64 (1.4-0ubuntu4.1) ...
Setting up wine1.4-i386:i386 (1.4-0ubuntu4.1) ...
Setting up wine1.4 (1.4-0ubuntu4.1) ...
Setting up wine (1.4-0ubuntu4.1) ...
Checking Wine version (Installed: 1.4-0ubuntu4.1)
$ apt-cache policy wine
wine:
Candidate: 1.4-0ubuntu4.1
Version table:
*** 1.4-0ubuntu4.1 0
500 http://archive.ubuntu.com/ubuntu/ precise-updates/universe amd64 Packages
1.4-0ubuntu4 0
500 http://archive.ubuntu.com/ubuntu/ precise/universe amd64 Packages
Now I have wine 1.4 installed I added ppa:ubuntu-wine/ppa repository again and:
$ sudo apt-get install wine1.5
wine:
Installed: 1.5.13-0ubuntu1
Candidate: 1.5.13-0ubuntu1
Version table:
*** 1.5.13-0ubuntu1 0
500 http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu/ precise/main amd64 Packages
1.4-0ubuntu4.1 0
500 http://mirror.globo.com/ubuntu/archive/ precise-updates/universe amd64 Packages
1.4-0ubuntu4 0
500 http://mirror.globo.com/ubuntu/archive/ precise/universe amd64 Packages
So finally I have wine 1.5 installed (^-^) thanks for Eric Carvalho and user1261084 help.
