$V(x)=\infty$ at $x=\pm L$ and $V=0$ for $|x|\leq L$ then consider the ground state$$\psi(x)=\sqrt{\frac{1}{L}}\cos\frac{\pi x}{2L}$$ notice the width is $2L$. The energy is $E=\frac{\hbar^2\pi^2}{8mL^2}$
I am unsure what does the instantaneous removal does to the particle. It becomes a wave packet but how?
I read a sentence from other post (1D Infinite Square Well: Box Suddenly Increases in Size. How treat this?) "wavefunction is just an initial condition", then I guess I also going to treat the infinite well ground state as a wave packet? Which means $$\varphi(k)=\sqrt{\frac{1}{2\pi L}}\int^{\infty}_{-\infty}\cos\frac{\pi x}{2L}e^{-ikx}\,dx=\sqrt{\frac{\pi}{2L}}\left[\delta(\frac{\pi}{2L}-k)+\delta(\frac{\pi}{2L}+k)\right]$$ and the time evolution would be $$\Psi(x,t)=\sqrt{\frac{1}{4L}}\int^{\infty}_{-\infty}\left[\delta(\frac{\pi}{2L}-k)+\delta(\frac{\pi}{2L}+k)\right]e^{ikx}e^{-i\frac{\hbar k^2}{2m}t}\,dk$$ $$\Psi(x,t)=\sqrt{\frac{1}{4L}}\left[e^{i\frac{\pi}{2L}[x-\frac{\pi}{4mL}t]}+e^{-i\frac{\pi}{2L}[x-\frac{\pi}{4mL}t]}\right]$$ Am I correct to this point? It's a superposition of two plane wave with same energy traveling to opposite direction. This matches the intuition in my mind where a wavepacket spread out
then the momentum are $\pm\frac{\hbar\pi}{2L}$, and this should be normalised since we start from a normalized initial wave function?
$\textbf{Update}$
To match $t=0$ the first integral should be integrated over $[-L,L]$ $$\varphi(k)=\sqrt{\frac{1}{2\pi L}}\int^{L}_{-L}\cos\frac{\pi x}{2L}e^{-ikx}\,dx=\sqrt{\frac{1}{2\pi L}}\frac {4 L\pi\cos (kL)} {-4 k^2 L^2 + \pi^2}=\frac{\sqrt{8\pi L} \cos(kL)}{-4 k^2 L^2 + \pi^2}$$ and the second integral, $t>0$ immediately extend over all space. So it would be over all space $$\Psi(x,t)=\sqrt{4L}\int^{\infty}_{-\infty}\frac{\cos(kL)}{-4k^2L^2+\pi^2}e^{ikx}e^{-i\frac{\hbar k^2}{2m}t}\,dk$$ and I think this is the correct time evolution
wet hkhsk
  • 135
No, that's not correct. It's the right idea, but the initial wavefunction is non-zero only on the interval $[-L,L]$, which changes your integral bounds. The resulting wavepacket is not a simple superposition of two plane waves, but rather an infinite number of them.
As an aside, it's an interesting exercise to see what about the initial state you can connect to this superposition. For example, $\varphi(k)$ should remain even in $k$, but see if you notice anything else about e.g. the superposition of momenta and energies present in the wavepacket, and then go back to argue why your observations should be true on general grounds. This is a useful way to gain real intuition from relatively simple toy problems.
Albatross
  • 72,909
