18
It is quite easy to derive the gravitational field intensity at a point within a hollow sphere. However, the result is quite surprising. The field intensity at any point within a hollow sphere is zero.
What exactly is the reason behind this? Except for, of course, the mathematics behind it. Is there any logic why the field intensity should be zero within a sphere? For example, it is logical to say that the field intensity would be zero at the center, as all the intensities cancel out. However, this cannot be the case for any point within the sphere.
Gummy bears
  • 1,612
One intuitive way I've seen to think about the math is that if you are at any position inside the hollow spherical shell, you can imagine two cones whose tips are at your position, and which both lie along the same axis, widening in opposite direction. Imagine, too, that they both subtend the same solid angle, but the solid angle is chosen to be infinitesimal. Then you can consider the little chunks of matter where each cone intersects the shell, as in the diagram on this page:
You still need to do a bit of geometric math, but you can show that the area of each red bit is proportional to the square of the distance from you (the blue point) to it--and hence the mass of each bit is also proportional to the square of the distance, since we assume the shell has uniform density. But gravity obeys an inverse-square law, so each of those two bits should exert the same gravitational pull on you, but in opposite directions, meaning the two bits exert zero net force on you. And you can vary the axis along which the two cones are drawn so that every point on the surface of the shell ends up being part of a pair like this, which leads to the conclusion that the entire spherical shell exerts zero net force on you.
Hypnosifl
  • 6,240
A part of the problem is first asking the correct question. If you reference a point inside a spherical torus (the perimeter is comprised of mass), the effects of gravity upon a mass (point) located somewhere inside the sphere will vary. So long as you deal only with a point, that will be the case.
However, if you deal with a solid sphere, instead of a 'point' inside the sphere, you have to deal with a concentric region inside the sphere. No matter how you define that concentric region, so long as the center resides at the main sphere's center, the net pull of gravity towards the outer perimeter remains a net force of zero.
