78
I thought the Hamiltonian was always equal to the total energy of a system but have read that this isn't always true. Is there an example of this and does the Hamiltonian have a physical interpretation in such a case?
Noah
  • 1,870
6 Answers6
29
In an ideal, holonomic and monogenic system (the usual one in classical mechanics), Hamiltonian equals total energy when and only when both the constraint and Lagrangian are time-independent and generalized potential is absent.
So the condition for Hamiltonian equaling energy is quite stringent. Dan's example is one in which Lagrangian depends on time. A more frequent example would be the Hamiltonian for charged particles in electromagnetic field $$H=\frac{\left(\vec{P}-q\vec{A}\right)^2}{2m}+q\varphi$$ The first part equals kinetic energy($\vec{P}$ is canonical, not mechanical momentum), but the second part IS NOT necessarily potential energy, as in general $\varphi$ can be changed arbitrarily with a gauge.
Siyuan Ren
  • 5,132
26
The Hamiltonian is in general not equal to the energy when the coordinates explicitly depend on time. For example, we can take the system of a bead of mass $m$ confined to a circular ring of radius $R$. If we define the $0$ for the angle $\theta$ to be the bottom of the ring, the Lagrangian $$L=\frac{mR^2\dot{\theta}^2}{2}-mgR(1-\cos{(\theta)}).$$ The conjugate momentum $$p_{\theta}=\frac{\partial L}{\partial \dot{q}}=mR^2\dot{\theta}.$$ And the Hamiltonian $$H=\frac{p_{\theta}^{2}}{2mR^2}+mgR(1-\cos{\theta}), $$ which is equal to the energy.
However, if we define the $0$ for theta to be moving around the ring with an angular speed $\omega$, then the Lagrangian $$L=\frac{mR^2(\dot{\theta}-\omega)^2}{2}-mgR(1-\cos{(\theta-\omega t)}). $$
The conjugate momentum $$p_{\theta}=\frac{\partial L}{\partial \dot{q}}=mR^2\dot{\theta}-mR^2 \omega.$$
And the Hamiltonian $$H=\frac{p_{\theta}^{2}}{2mR^2}+p_{\theta}\omega+mgR(1-\cos(\theta-\omega t)), $$ which is not equal to the energy (in terms of $\dot{\theta}$ it has an explicit dependence on $\omega$).
Dan
  • 5,795
14
Goldstein's Classical Mechanics (2nd Ed.) pg. 349, section 8.2 on cyclic coordinates and conservation theorems' has a good discussion on this. In his words:
The identification of H as a constant of the motion and as the total energy
are two separate matters.  The conditions sufficient for one are not
enough for the other.
He then goes on to provide an example of a 1-d system in which he chooses two different generalized coordinate systems. For the first choice, H is the total energy while for the second choice H ends up being just a conserved quantity and NOT the total energy of the system.
Check it out. It's a very nice example.
A little complicated but interesting is the Lagrangian of a damped harmonic oscillator (Havas' Lagrangian [1]):
$$ L = \frac{2m\dot{x} +kx}{x\sqrt{4mK-k^2}}\tan^{-1}\left(\frac{2m\dot{x} + kx}{x\sqrt{4mK -k^2}} \right) ~-~ $$ $$ - \frac{1}{2}\ln (m\dot{x}^2 + kx\dot{x} + Kx^2) $$
The Lagrangian is time-independent, so the corresponding Havas' Hamiltonian
$$ H = \,-~ \frac{kpx}{2m} ~-~ \ln \cos\bigg(\frac{px}{2m}\sqrt{4mK-k^2}\bigg) ~+\, \ln x $$ is constant in time. Since total energy of a damped harmonic oscillator decreases in time, the above $H$ can't be total energy.
[1] Havas P., The Range of Application of the Lagrange Formalism - I,Nuovo Cim. 5(Suppl.), 363 (1957)
Page 60-64 Goldstein, Poole and Safko (3rd Edition) goes into a really nice derivation and description of the Energy Function. In the footnotes it states that this is equivalent to the Hamiltonian (it is just not in the correct generalized coordinates for the Hamiltonian). If this function is derived from scleronomous (equations of constraints are time independent) and there is no $\dot{q}$ dependence in the potential energy, then you can show that h=T+V. These conditions make sure that T is 2nd degree homogeneous according to Euler's Theorem, and this is the condition that allows transformation to T+V.
This is all shown very nicely in Goldstein.
The Hamiltonian of a system is equivalent to the total energy of the system, if and only if, the following condition(s) are satisfied:
Keep in mind, that Hamiltonian being the $Legendre$ $Transformation$ of the $Lagrangian$, we need to consider the structure of the $Lagrangian$, in order to determine the $Hamiltonian$ of a system.
$1.$ The Lagrangian: $L$, must have the form, $L$ = ($T$ - $V$), and in order to have this, we need to consider the $d'Alembert's Principle$, which gives:
$$\frac{\mathrm{d} }{\mathrm{d}t}{(\frac{\partial T}{\partial \dot{q_i}}) - \frac{\mathrm{d}T}{\mathrm{d}q_i} = Q_j}{ ...... (\alpha)}$$
Where this $Q_j$ is the generalize force component for the $j$-th generalized co-ordinate, which is the forces of constraint(s).
Clearly, for:
Constraints of motion being explicit time-dependent (Force exerted on the system can have explicit time dependence) it is different, but for very general purposes, where the force(s) acting on the system can be directly derived from its respective scaler potential i.e. for
Conservative force field, we can write, $$Q_j = F_j = -\nabla_j (V) $$, i.e. the scaler potential, and simplifying the $(\alpha)$, we get $L = (T-V)$
$Note$ $that$: In cases of presence of vector potential, like for EM field, there's another case of explicit time-dependence, when fields are dependent on time, which constitutes another aspect, i.e. for time-varying potential, we cannot explicitly write the $Lagrangian$ in that fashion. But the $Hamiltonian$ formed in this way, will still satisfy being the total energy of the system.
Now, we can conclude that, for time-dependent constraint(s) of a motion, we cannot say that $Hamiltonian$ is equivalent to the $Total$ $Energy$ of the system.
