I'm almost embarrased to ask this question because I thought I was by now very confident with classical mechanics.
Someone has stated that given a mechanical system with a Lagrangian $L$ s.t. $\frac{\partial L}{\partial t}=0$ where the kinetic energy $T$ is NOT homogeneous quadratic in the generalised velocities, one cannot infer that the total energy $E=T+V$ is NOT conserved.
However, I think this is already enough to show that $\dot{E} \neq 0$.
Let's assume that $L$ looks as follows: $L = \frac{1}{2}(\dot{q}^2 + 2 \dot{q}f(q))-V(q)$.
Then, after plugging in the equation of motion $\ddot{q} = -V^{\prime}$, I obtain \begin{equation} \dot{E} = \dot{q} [\dot{q}f^{\prime}(q) - V^{\prime}(q)f(q)]. \end{equation}
I can't see how one can make this vanish.
To me it is clear that scleronomic constrains imply that $T$ is homogeneous quadratic in $\dot{q}$. Then, one has of course energy conservation. But, does $T$ being not homogeneous quadratic in $\dot{q}$ also imply that there is a rheonomic constraint? (Because then it is also physically clear, why $E$ is not conserved.)
I'd be grateful for answers!
psm
  • 909
It is actually clear that $T$ being NOT homogeneous quadratic in the velocities of the generalized coordinates does not imply that energy is not conserved. E.g. one can consider a boost transformation for a free particle in 1D and then $T=\frac{1}{2}m\dot{x}^2$ becomes $T=\frac{1}{2}m(\dot{x}-c)^2$. Clearly, $E$ is conserved.
Unfortunately, I wasn't thinking of boosts or of adding total time deivatives to the Lagrangian. Embarrassing.
psm
psm
  • 909
