Before posting this, I looked at 24 different duplicate questions including: How do I install Ubuntu to a USB key? (without using Startup Disk Creator). I couldn't find a single question that dealt with this. So, please don't mark duplicate unless there truly is another question asking this...
Now that I've followed the directions for creating a a bootable USB stick on macOS, and it works flawlessly, how do I make it permanent, rather than a trial/installer?
I believe this will help Windows users too. My ultimate goal is to have a single USB stick that I can use on Mac or PC, but in the end may have to carry 2
The directions I linked above are excellent! It worked perfectly. I'm not one of those people who can't follow directions. The problem is that the directions ended too soon.
Here is what I mean by "make it permanent"
- When I boot off the USB stick, I get GRUB menu offering "Try Ubuntu without installing", "Install Ubuntu", "OEM install (for manufactures)", and "Check disk for defects"
- I want this to boot straight into a full Ubuntu Install.
- When I boot into "Try Ubuntu", the drive is very small.
- I want to make the full space of my 32GB USB stick available
- I don't want to waste my precious little space on tools for installing Ubuntu on another drive. (This is my drive!)
- The drive seems to be in a Guest/Read-only-ish mode.
- I tried to remove the media files in the Examples directory linked on the Desktop and got an error
- I tried to downloaded the google-chrome-stable deb from Google, but...
- the Ubuntu GUI installer doesn't even seem to try to open it.
dpkg -iwon't install it because of 3 dependencies.- apt can't locate any of the 3 dependencies.
- none of the answers on How to install Google Chrome work for me.
- [ I fully realize that the Chrome issue may be a red herring ]
Let me clarify my criteria
EDIT: I can't believe I'm doing this again, but here we go... Let me take the big bold question at the top, and break it down phrase by phrase...
- Now that I've followed the directions for creating a a bootable USB stick on macOS,
- If you are calling this question a duplicate of another and the other does not specifically address following those directions, it is a different question
- and it works flawlessly,
- If you are calling this question a duplicate of another and the other is about failing to follow those directions, it is a different question
- how do I make it permanent,
- The key word there is it. What does that pronoun refer too? A USB drive that was created in about 2 minutes by
dding an ISO on to it. What does it NOT refer too? A USB drive that created over the course of hours by using it as the target of the GUI Ubuntu installer. - If you are calling this question a duplicate of another and the other does not populate the USB drive via
ddor Etcher, it is a different question
- rather than a trial/installer?
- If you are calling this question a duplicate of another and the other produces the Live CD/trial/installer, it is a different question
I want my hard drive to be untouched.
- I don't want to make an Ubuntu USB "install disk".
- I do want to Ubuntu installed on a USB disk.
- The answer may very well be that it's not possible to do.
- REMINDER: My question is in bold at the top
- The answer may be that I have to try something else
- This question is not a duplicate.
- If the answer turns out that I have to try something else, that's okay. But marking the question as a duplicate prevents smart people from considering the question.
Please don't be nasty
Before you vote to close this, put it on hold, mark it duplicate, or kill my dog, post a comment and lets see if we can improve the question to your satisfaction. I'm doing this for posterity. Please don't be nasty.
