295
I followed the uninstall instructions here. Then I ran these commands:
sudo apt-get purge docker-engine
sudo apt-get autoremove --purge docker-engine
rm -rf /var/lib/docker
So after I did all this I ran this command to see if docker files are any where else:
sudo find / -name '*docker*'
I found several places where docker files still exists.
/etc
/sys
/lib
/usr
/usr
/run
/proc
/var
Docker exists in subfolders in the list above. I can post every path if you like. There is about 200 locations.
Is there a way to totally and completely remove docker everywhere?
Luke101
  • 3,053
9 Answers9
534
To completely uninstall Docker:
Step 1
dpkg -l | grep -i docker
To identify what installed package you have:
Step 2
sudo apt-get purge -y docker-engine docker docker.io docker-ce docker-ce-cli docker-compose-plugin
sudo apt-get autoremove -y --purge docker-engine docker docker.io docker-ce docker-compose-plugin
The above commands will not remove images, containers, volumes, or user created configuration files on your host. If you wish to delete all images, containers, and volumes run the following commands:
sudo rm -rf /var/lib/docker /etc/docker
sudo rm /etc/apparmor.d/docker
sudo groupdel docker
sudo rm -rf /var/run/docker.sock
sudo rm -rf /var/lib/containerd
sudo rm -r ~/.docker
You have removed Docker from the system completely.
34
Collaborated list collected from above posts and comments fro removing docker and docker-compose:
sudo umount /var/lib/docker/
sudo rm -rf /usr/bin/docker-compose
Raghav
  • 783
15
Add docker-ce-cli package also while doing purge of docker
Thinh NV
  • 143
11
An update on uninstalling docker
Just an update on this, after I had to deal with the same issue.
Here is the official docker documentation on removing docker.
Remove the latest version:
Uninstall the Docker Engine, CLI, and Containerd packages:
sudo apt-get purge docker-ce docker-ce-cli containerd.io
Delete all images, containers, and volumes:
Remove previous versions:
sudo apt-get remove docker docker-engine docker.io containerd runc
David
  • 211
Steps performed in order to remove docker on Centos 7:
yum list installed|grep -i docker
yum remove containerd.io.x86_64 docker-ce.x86_64 docker-ce-cli.x86_64
groupdel docker
ls /var/lib/docker/
find /var -iname "*docker*"
Hope this information could be helpful for someone.
Best regards,
Remove docker completely using the following commands in a terminal:
sudo apt remove --purge docker-ce docker-ce-cli containerd.io
sudo apt autoremove -y
sudo apt autoclean
MD SHAYON
  • 415
Refreshing installation of Docker desktop and docker-ce after testing installation of Docker Desktop
After uninstalling docker desktop from ubuntu 22.04 and docker-ce (removing everything)
Then reinstalling docker engine (ce) alone as I want to run docker instance on host and separately on qemu/virt and being able to run hello-world I was getting this error
$ docker ps Cannot connect to the Docker daemon at unix:///home/christian/.docker/desktop/docker.sock. Is the docker daemon running?
Despite the user having docker group membership and permissions.
What was happening that despite uninstalling docker-desktop completely and docker-ce and then reinstalling from scratch I kept getting this error. There was no .docker/desktop/ folder
I found a config.json file .docker/config.json
that had a line "credsStore": "desktop", "currentContext": "desktop-linux"
So I copied it to a .bak extension and from then docker commands work properly without sudo
So it looks like uninstalling Docker Desktop is leaving at least that leftover behind.
crislar
  • 31
// check docker is installed or not
// remove volume , network , container and image files
sudo docker volume prune -f
sudo docker network prune -f
sudo docker container prune -f
sudo docker image prune -a
// remove docker
sudo apt purge docker
or
sudo apt remove docker
// remove dependency packages related to docker
sudo apt autoremove
sudo apt autoclean
for details : read
You can identify the packages those files originated from with a command like dpkg-query -S $(sudo find / -name '*docker*' -print 2>/dev/null). Any such packages that you do not need, you can remove with sudo apt-get purge <package>. Please use care when you do so as some packages include some support for docker, but you might not want to remove, say, a text editor or a file manager for that reason.
If some files did not originate from packages (indicated by "dpkg-query: no path found matching pattern path"), you can remove them individually. Again, please use caution, as there may be files unrelated to the docker you want to remove, which simply have the string "docker" in their names.
taneli
  • 2,629
