I have attempted to install docker-ce for hours now without success.
I am running vanilla 18.04 and have used both the official and the DigitalOcean installation guides which both produce the same error.
Attempted solutions:
- this step-by-step answer to remove Docker completely before any reattempt.
- I have downloaded and tried older versions per the advise from this blog post
- I have disabled my VPN service which has been suggested elsewhere on AskUbuntu.
Output sudo apt-get install docker-ce:
Reading package lists... Done
Building dependency tree
docker-ce is already the newest version (5:19.03.13~3-0~ubuntu-bionic).
0 upgraded, 0 newly installed, 0 to remove and 69 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up docker-ce (5:19.03.13~3-0~ubuntu-bionic) ...
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2020-11-13 16:33:18 CET; 7ms ago
Docs: https://docs.docker.com
Process: 14405 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 14405 (code=exited, status=1/FAILURE)
dpkg: error processing package docker-ce (--configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
docker-ce
Output systemctl status docker.service:
Active: failed (Result: exit-code) since Fri 2020-11-13 16:33:25 CET; 4min 36s ago
Process: 14540 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 14540 (code=exited, status=1/FAILURE)
Nov 13 16:33:25 biskop systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Nov 13 16:33:25 biskop systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 13 16:33:25 biskop systemd[1]: Stopped Docker Application Container Engine.
Nov 13 16:33:25 biskop systemd[1]: docker.service: Start request repeated too quickly.
Nov 13 16:33:25 biskop systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 13 16:33:25 biskop systemd[1]: Failed to start Docker Application Container Engine.
Any help would be greatly appreciated.
