I recently updated from ubuntu 18.04 to ubuntu 20.04. I would like to develop on ubuntu 20.04 with nvidia-docker.
When I try to use the docker with the updated version, I get the following error.
docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]].
Then I uninstalled the docker system according to this cite and reinstalled it according to this site.
How do I solve this problem?
musako
  • 201
Follow this instructions for install docker-nvidia and docker-compose :
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable"
sudo apt-get update
sudo add-apt-repository \
   "deb [arch=amd64] https://download.docker.com/linux/ubuntu \
   $(lsb_release -cs) \
   stable"
sudo apt-get install docker-ce=18.03.1~ce~3-0~ubuntu
curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | \
  sudo apt-key add -
distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | \
  sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update
sudo apt-get install -y nvidia-docker2
sudo pkill -SIGHUP dockerd
sudo systemctl start docker
sudo systemctl enable docker
sudo groupadd docker
sudo gpasswd -a $USER docker
sudo usermod -aG docker $USER
sudo curl -L "https://github.com/docker/compose/releases/download/1.24.0/docker-compose-$(uname -s)-$(uname -m)" -o /usr/bin/docker-compose
sudo chmod +x /usr/bin/docker-compose
unistall docker now in my pc(follow this cite).
And follow this cite.
musako
  • 201
