I tried uninstall Docker and VS code from my Ubuntu 23.04 OS in my dual boot computer. The other OS in my dual boot computer is Windows 11 (This was the first OS of my computer prior to getting dual boot setup)
To uninstall Docker I entered the following in terminator as shown in https://webhostinggeeks.com/howto/how-to-uninstall-docker-on-ubuntu/#:~:text=Commands%20Mentioned,configurations%2C%20images%2C%20and%20volumes. :
sudo docker stop $(sudo docker ps -aq)
sudo apt-get purge docker-ce docker-ce-cli containerd.io
sudo rm -rf /var/lib/docker
sudo apt-get autoremove
sudo apt-key del $(sudo apt-key list | grep Docker | awk ‘{print $2}’)
I also entered the following as shown in How to completely uninstall docker :
dpkg -l | grep -i docker
sudo apt-get purge -y docker-engine docker docker.io docker-ce docker-ce-cli docker-compose-plugin
sudo apt-get autoremove -y --purge docker-engine docker docker.io docker-ce docker-compose-plugin
sudo rm -rf /var/lib/docker /etc/docker
sudo rm /etc/apparmor.d/docker
sudo groupdel docker
sudo rm -rf /var/run/docker.sock
sudo rm -rf /var/lib/containerd
sudo rm -r ~/.docker
Then I entered the following to uninstall VS Code as shown in How do I uninstall Visual Studio Code? :
sudo apt purge code
sudo apt autoremove
rm -rf ~/.vscode ~/.config/Code
However after this, I entered:
sudo apt update
which returned:
Hit:1 https://download.docker.com/linux/ubuntu lunar InRelease
Hit:2 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://archive.ubuntu.com/ubuntu lunar InRelease
Ign:4 http://packages.ros.org/ros2/ubuntu lunar InRelease
Hit:5 http://archive.ubuntu.com/ubuntu lunar-updates InRelease
Err:6 http://packages.ros.org/ros2/ubuntu lunar Release
  404  Not Found [IP: 2600:3404:200:237::2 80]
Hit:7 http://archive.ubuntu.com/ubuntu lunar-backports InRelease
Hit:8 http://archive.ubuntu.com/ubuntu lunar-security InRelease
Hit:9 https://packages.microsoft.com/repos/vscode stable InRelease
Hit:10 https://packages.microsoft.com/repos/code stable InRelease
Reading package lists... Done
W: Target Packages (stable/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target Packages (stable/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target DEP-11 (stable/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target DEP-11 (stable/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target DEP-11-icons-small (stable/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target DEP-11-icons (stable/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target DEP-11-icons-hidpi (stable/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target CNF (stable/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
W: Target CNF (stable/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/archive_uri-https_download_docker_com_linux_ubuntu-lunar.list:1 and /etc/apt/sources.list.d/docker.list:1
E: The repository 'http://packages.ros.org/ros2/ubuntu lunar Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
My question is how to get rid of the "Err:6", "W:", "E:" and "N:" messages that were returned?
I am a beginner-intermediate in Ubuntu and VS code and, new to Docker. Thank you for your help in advance!
Viv
W is a Warning and explains the reason:
so remove the duplicates and it goes away.
that URL does not exist. Probably ros2 does not exist for "lunar" Either remove it or change "lunar" to a supported release.
will disappear after you fixed the previous one.
Rinzwind
  • 309,379
