Distributor ID: Ubuntu
Description:    Ubuntu 22.04.1 LTS
Release:    22.04
Codename:   jammy
I am trying to delete and uninstall everything docker related so that I can make a clean re-install. I have followed these tutorials:
How to completely uninstall docker
https://docs.docker.com/compose/install/uninstall/
I have run the following commands in order:
sudo rm -rf /var/lib/docker /etc/docker
sudo rm /etc/apparmor.d/docker
sudo groupdel docker
sudo rm -rf /var/run/docker.sock
sudo apt-get purge -y docker-engine docker docker.io docker-ce docker-ce-cli docker-compose-plugin
sudo apt-get autoremove -y --purge docker-engine docker docker.io docker-ce docker-compose-plugin
And I thought I got rid of it, but then:
dpkg -l | grep -i docker
ii  docker-compose                             1.29.2-1                                all          define and run multi-container Docker applications with YAML
ii  python3-docker                             5.0.3-1                                 all          Python 3 wrapper to access docker.io's control socket
ii  python3-dockerpty                          0.4.1-2                                 all          Pseudo-tty handler for docker Python client (Python 3.x)
I still have docker-compose 1.29.2-1 and this one won't go away no matter the command:
sudo apt-get purge -y docker-componse
Reading package lists... Done
Building dependency tree... Done
E: Unable to locate package docker-componse
sudo apt-get remove docker-compose-plugin Reading package lists... Done Building dependency tree... Done Reading state information... Done Package 'docker-compose-plugin' is not installed, so not removed
rm $DOCKER_CONFIG/cli-plugins/docker-compose rm: cannot remove '/cli-plugins/docker-compose': No such file or directory
rm /usr/local/lib/docker/cli-plugins/docker-compose rm: cannot remove '/usr/local/lib/docker/cli-plugins/docker-compose': No such file or directory
sudo snap remove docker snap "docker" is not installed
rm /usr/local/bin/docker-compose rm: cannot remove '/usr/local/bin/docker-compose': No such file or directory
sudo apt-get purge docker-ce-cli Reading package lists... Done Building dependency tree... Done Reading state information... Done Package 'docker-ce-cli' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
rm -r /home/george/.docker
sudo rm $(which docker-compose)
dpkg -l | grep -i docker ii docker-compose 1.29.2-1 all define and run multi-container Docker applications with YAML ii python3-docker 5.0.3-1 all Python 3 wrapper to access docker.io's control socket ii python3-dockerpty 0.4.1-2 all Pseudo-tty handler for docker Python client (Python 3.x)
which docker-compose return nothing.
docker-compose 1.29.2-1 is still there.
What is that and how can I get rid of it ?
This is the old version of Docker compose, which is not in the current repos.
Try uninstalling directly with dpkg:
dpkg -P docker-compose
This does not check for any repos or dependencies, and simply purge the package, no questions asked.
Artur Meinild
  • 31,035
