I installed Ubuntu 17.04 from a USB on my Acer Spin 5 which came with Windows 10. I made the choice of removing Win10 because earlier when I Dual-booted Ubuntu and Windows 10 I was not able to boot into Ubuntu after a Windows update.
Now when I start my computer it says
Default boot device missing or boot failed. Insert recovery media and hit any key, Then select "boot manager" to choose a new boot device or to boot recovery media
If entering this I only get the choice of booting with Windows Boot Manager which takes me back to this screen again, I'm also able to use my live-USB with Ubuntu and either load into Ubuntu live or install directly, both this options brings me back to the "Default boot device..." after a reboot. I've also tried boot repair with the following commands
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
But now after reboot I get
Failed to open \EFI\Boot\grubx64.efi - Not found
Failed to load image \EFI\grubx64.efi: Not found
 start_image() returned Not found
Failed to open "\EFI\BOOT\Microsoft\grubx64.efi - Not found
Failed to load image \EFI\Microsoft\BOOT\grubx64.efi Not found
How do I solve this problem with not being able to get into Ubuntu?
Boot repair summary
How do I know which partition is my main partition? Running
sudo fdisk -l
gives
Disk /dev/loop0: 1.5 GiB, 1553670144 bytes, 3034512 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sda: 238.5 GiB, 256060514304 bytes, 500118192 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: F2E8B05E-6E0D-493F-9FF1-9F5D1195680B
Device       Start       End   Sectors  Size Type
/dev/sda1     2048   1050623   1048576  512M EFI System
/dev/sda2  1050624 500117503 499066880  238G Linux filesystem
Disk /dev/sdb: 3.7 GiB, 4002910208 bytes, 7818184 sectors
Disklabel type: dos
Disk identifier: 0x1b571474
Device     Boot   Start     End Sectors  Size Id Type
/dev/sdb1  *          0 3142655 3142656  1.5G  0 Empty
/dev/sdb2       3118960 3123567    4608  2.3M ef EFI (FAT-12/16/32)
Zanna
  • 72,312
Every Acer we have seen needs you to enable a UEFI Supervisory password and from within UEFI drill down to the grub/ubuntu .efi boot files in the ESP and enable trust.
This seems to be unique to Acer.
But better than many other systems that require working around limits built into UEFI to only Boot Windows.
More details on password & trust settings:
http://askubuntu.com/questions/597213/bootable-device-not-found-after-clean-install-of-ubuntu-14-04-uefi
Acer video on setting Supervisory Password.
Zanna
  • 72,312
oldfred
  • 12,583
