OS to Install
  • Attempted OS: Ubuntu 24.04 (Noble Numbat)
  • Desktop Image: 64-bit (AMD64)
  • GNU GRUB: version 2.12
Installation Details
  • Disk setup: Erase disk and install Ubuntu
  • Installation disk: WDC WD10... sda
  • Applications: Default selection
  • Disc encryption: None
  • Proprietary software: Codecs & drivers
  • Partitions
    1. partition sda1 formatted as fat32 used for /boot/efi
    2. partition sda2 formatted as ext4 used for /
Computer Details
  • Product Name: Aspire E5-574G
  • Manufacturer: Acer
  • CPU Type: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
  • System BIOS Version: V.1.14
  • F12 Boot Menu: [Enabled]
  • Supervisor Password: Set
  • Secure Boot: [Enabled]
  • Boot Mode: UEFI
  • Boot Priority Order:
    1. HDD
    2. USB HDD
    3. USB FDD
    4. ATAPI CDROM ....
    5. (option 8) EFI File Boot 0: Yes
I can get through the entire install with no issues. This is not a dual boot, I want to run this Ubuntu install as the primary OS. When attempting to reboot after successful install, I get to a screen that tells me to "remove bootable medium and press ENTER". At this point, the computer restarts and then cannot boot. The only option that is available is "1. Yes".
I have visited ACER forums and have not seen a solution for this. Same problems manifests with older LTS versions of Ubuntu, and with Linux Mint Cinnamon 22.
