2 days ago, i installed ubuntu for the first time, i installed it on acer es1-332 laptop, and i used option erase and "install ubuntu", what happend next? i cannot boot linux from "hard drive", it show no device, as a live from pendrive it work fine, i tried disable/enable secureboot, after use "boot-repair" bios show linux as "windows boot manager" i found on some forum becouse i erased pre-installed windows, i erase uefi as well, so stuff i know not work (installation ubuntu again, boot-repair) only solution that i found there is change to legacy boot, but i couldnt find anything like that in my bios option. i am a newbie on linux, i so i need your help guys
i dont care about windows i just need ubuntu machine.
Here are a few things to try:
  • Make sure secure boot is off, it can't boot otherwise
  • It seems obvious, but try reinstalling ubuntu, try the advanced mode to fiddle around with partitions. Make sure there's a swap partition, root partition and maybe a boot partition (Source)
  • Try using a different program to write ubuntu to your flash drive and make sure to confirm the checksum is the same as the one on the website.
Hopefully this helps (it probably won't)
