I have an application installed on my Samsung NP-RV509 which makes the Fn keys work properly.
I have determined that the startup of this application is the reason for almost 30 extra seconds of booting time.
Can I write a shell/python script (I, myself, can't actually do this as I don't know shell/python programming) that will introduce a delay by maybe using a loop or something and then start the above application? Shall I add/apply this script in startup apps?
This should effectively simulate the running of that program at startup, but it would be delayed in actuality.
How can I achieve this?
mickmackusa
  • 852
  • 20
Nirmik
  • 7,938
You can add a delay time with sleep command.
man sleep for more info .
Example
I want to startup a program with delay of 10 seconds. I create an entry in the startup applications with this in command field
sleep 10;/usr/bin/<program name>
Example 2
I want to create a script with the delay (sleep) option and add this script to startup applications
gedit delayscript.sh
and I add these lines
#!/bin/bash
sleep 10
save the script and give it executable permissions
chmod +x delayscript.sh
and add it to startup applications (command field) with full path
/home/username/delayscript.sh
NickTux
  • 17,865
  • 57
  • 66
while this is a great answer:
sleep 30; <app-name>
It does have one hidden downside: if you ever want to kill the delayed app before it starts to run, it's not anywhere in ps -ef; instead all you see is "sleep 30". And, if you kill that sleep command, rather than preventing the delayed app from running it just makes the app run immediately. So I suggest this alternate script (delay) which, if killed, prevents the delayed app from running:
#!/bin/bash
# easily killable sleep
sleep $1
shift
example:
delay 10m rebuild-database
now, if you decide for some reason to prevent the database from being rebuilt, you can kill the shell script.
Al Ro
  • 111
