I've recently came back to Ubuntu from Kubuntu, but I really like Dolphin. Is there any way how to set it up as default file manager?
To view the current default for opening directories:
xdg-mime query default inode/directory
To set Dolphin as default:
xdg-mime default org.kde.dolphin.desktop inode/directory
To set Thunar as default:
xdg-mime default thunar.desktop inode/directory
Run either on the terminal as regular user. If you want to set the default to another file manager, install the file manager, and find the correct .desktop file by searching in /usr/applications/ on the command-line.
Related files:
/usr/share/applications/defaults.listsystem-wide defaults$HOME/.local/share/applications/mimeapps.list$HOME/.config/mimeapps.listwherexdg-mimesaves configuration
Sources:
Steps:
Open a terminal, e.g. using Ctrl+Alt+T
Install
exo-utilsby running the following command in the terminal:sudo apt-get install exo-utilsRun the following command in the terminal:
exo-preferred-applicationsIn the window that opens, click on Utilities
On the File Manager section, click the drop-down menu arrow + Other...
Find
/usr/share/applicationsdirectoryAdjust to show all files and select
dolphin.desktop(wherever you find it)Click close
- 231
- 378
Adding to Rucent88 answer:
For me the dolphin desktop file was stored in /usr/share/applications/org.kde.dolphin.desktop. So
did the trick.
Keep in mind to have a look where the desktop link is located. Have a look at the file list of your installed file manager to see how the desktop link is called if you can't find it.
- 171
- 1
- 2
As exo-preffered-applicatiosn from exo-utils have been depreciated and moved to xfce4-settings. Use the following steps:
- Open the terminal
Ctrl+Alt+T. - Install xcfe4-settings
sudo apt install xfce4-settings - Type
xfce4-mime-settingsin terminal. - A window will appear, click on Utilities in it.
- Go to File Manager section and click on others
- Open /usr/share/applications directory and set from exectuable files to all files.
- Select for org.kde.dolphin.desktop and open it.
- Close
also it works only with:
xdg-mime default dolphin.desktop inode/directory application/x-gnome-saved-search
From: http://www.fandigital.com/2013/01/set-nemo-default-file-manager-ubuntu.html
In My, Ubuntu 20.04.2 LTS below solution worked. Not sure, is there are any consequences for this approach.
In file /usr/share/applications/defaults.list modified entry inode/directory=org.gnome.Nautilus.desktop to inode/directory=org.kde.dolphin.desktop
- 167
