My desktop appears to be broken. I can no longer see any shortcuts I placed on my desktop. When holding down the mouse and then moving the mouse I also no longer see any selection area. The desktop background is stuck at whatever it was at the login screen (trying to change the background in the settings menu has no effect).
Luckily the side bar with program links still works. All GUI programs still work so it seems to be isolated to the desktop.
Is there any way to reset the desktop? I'm not really sure what I did to cause this. A recent change I did make was trying to change my default file browser from Nautilus to Krusader using the top answer in this post. Please note the poster of this question was asking for Dolphin not Krusader. Maybe this caused the error. I can't think of anything else that might have caused this.
I already tried the suggestions on this website but they did not work.
I use Ubuntu 14.04 LTS 64 bits with the latest updates.
Mathyn
  • 253
I fixed the problem. After some more searching around I discovered Nautilus was removed from my system. I discovered this because I could not launch Nautilus from a terminal window (command not found).
After installing Nautilus using
sudo apt-get install nautilus
and doing a reboot everything worked again.
I have no idea how I managed to get Nautilus removed from my system.
Mathyn
  • 253
