I like Nautilus, but it suffers from lag when navigating between folders. I estimate the delay at somewhere between 300ms-800ms. Not much, but enough to notice and feel sluggish compared to Windows Explorer (running on Windows 7 on the same machine on a different disk).
Are there alternatives that will respond more quickly?
N.B. I'm running 12.10. The Ubuntu partition is on an SSD while the Win7 partition is on an HDD, so I find the difference in responsiveness particularly strange.
jl6
  • 294
Thunar file manager is designed to be fast, lightweight, and easy-to-use.
To install Thunar in Ubuntu 12.10, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below:
sudo apt-get install thunar
For Ubuntu 12.04, add the Xfce 4.12 PPA. To do so, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below:
sudo add-apt-repository ppa:xubuntu-dev/xfce-4.12
sudo apt-get update && sudo apt-get upgrade
Mitch
  • 109,787
Options
Both Thunar and PCManFM are valid alternatives to Nautilus and more responsive in general, with PCManFM being ever so slightly faster than Thunar. As both of these options have already been mentioned in different answers I would like to point you to yet another alternate file browser: Dolphin.
Dolphin
Out of all file managers on Ubuntu, Dolphin it is both the fastest and most feature-rich. However, as a Kubuntu application it comes with a long list of KDE dependencies. These won't harm you but will take up additional disk space. And because Dolphin does not use the shared GNOME libraries it will likely take slightly longer to start than the aforementioned alternatives.
Installation
You can install dolphin with:
sudo apt-get update && apt-get install dolphin --no-install-recommends
Setting up the default
Here is a Q&A on setting an alternate file manager up as Ubuntu's default:
How to set up Dolphin as default file manager?
This Q&A deals with Dolphin, specifically:
How to run Dolphin instead of Nautilus?
Glutanimate
  • 21,763
PcManFM is a small and very fast file manager which is used in Lubuntu and is very easy to install through the Software Center.
Here is a tutorial on setting up PCManFM as the default file manager on Ubuntu:
How to set PcManFm as the default file manager?
