107
I upgraded my laptop to have the 4.8 kernel and during the process the following warnings came up.
update-initramfs: Generating /boot/initrd.img-4.8.0-040800-generic
W: Possible missing firmware /lib/firmware/i915/kbl_dmc_ver1_01.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_ver9_14.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_ver8_7.bin for module i915
These seem a little odd to me as my CPU is i7-6700HQ which is a skylake and my understanding is that these are for different CPUs? I followed the instructions here prior as in the past I had warnings regarding my CPU family.
Are these warnings things I should just ignore, or should I install the guc/dmc drivers for those CPU families?
Malachi
  • 1,397
6 Answers6
158
May 20, 2019 Update
To answer your question you don't need to update drivers for a processor you aren't running but it is nice to see the warnings disappear when you do.
Today I received these warning:
update-initramfs: Generating /boot/initrd.img-5.0.1-050001-generic
W: Possible missing firmware /lib/firmware/i915/skl_dmc_ver1_27.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_dmc_ver1_04.bin for module i915
W: Possible missing firmware /lib/firmware/i915/cnl_dmc_ver1_07.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_dmc_ver1_07.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_ver9_39.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_ver9_29.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_guc_ver9_33.bin for module i915
I downloaded the blobs (described in next section) and then used:
$ sudo cp ~/Downloads/*.bin /lib/firmware/i915/
$ sudo update-initramfs -u update-initramfs: Generating /boot/initrd.img-5.0.1-050001-generic
Now my Sky Lake (skl) drivers are up to date and I can try out latest kernel parameters recommended on the internet. Warning messages for future processors Kaby Lake (kbl), Cannon Lake (cnl) and Ice Lake (icl) are gone making life less stressful.
May 26, 2018 Update
Minor revision August 6, 2018.
New download screen of "blobs"
Recently Intel has created a new download page and new web page layout:
Intel i915 firmware blobs
The download files are now called firmware blobs which is new-speak for firmware drivers. It stands for Binary Large OBject (BLOB).
Drivers are sorted by processor:
  • bxt Broxton, Canceled in 2016, successor to Cherry Trail processors
  • kbl Kabylake, 7th generation, eg i7-7700
  • skl Skylake, 6th generation, eg i7-6700
Then drivers are organized by subgroup (full explanation here):
  • GUC - GuC is designed to perform graphics workload scheduling on the various graphics parallel engines.
  • DMC - DMC provides additional graphics low-power idle states.
  • HUC - HuC is designed to offload some of the media functions from the CPU to GPU.
Match error message to driver needed
Compare the error message you are receiving by update-initramfs or update-grub to find the missing driver. In your example the message was "/lib/firmware/i915/kbl_guc_ver9_14.bin" so you are missing the Kabylake GuC called: kbl_guc_ver9_14.bin in the web page shown above. You don't want the newer one: kbl_guc_ver9_39.bin
Download driver needed
There is no more installation script as in past versions. Simply highlight the missing driver (blob) and click on it. This screen appears:
Initially you only see the "hex dump" but after clicking the link titled plain a download window appears as illustrated above.
Click "Save File"
Install driver with simple sudo cp (copy command)
After downloading, installation is a simple sudo cp (copy command) and there are no complicated tar commands, or ./script_name installation steps.
Quick Install
cd ~/Downloads
sudo cp kbl_guc_ver9_14.bin /lib/firmware/i915
sudo cp bxt_guc_ver8_7.bin /lib/firmware/i915
IMPORTANT: Replace kbl_guc_ver9_14.bin and bxt_guc_ver8_7.bin above with the missing driver names you downloaded.
VOILA! New driver is installed. Much simpler than previous installation methods for missing Intel i915 drivers!
TL;DR Exploratory Installation
I already had the driver installed. This lengthy installation method gives you an idea of before and after effects of copying the BLOB:
$ sudo updatedb
$ llocate kbl_guc_ver9_14.bin
ACCESS      OWNER  GROUP  SIZE    MODIFIED    NAME (updatdb last ran: 2018-05-26 12:07:57)
-rw-rw-r--  rick   rick   142656  2018-05-26  /home/rick/Downloads/kbl_guc_ver9_14.bin
-rw-rw-r--  rick   rick   142656  2017-02-24  /home/rick/Downloads/kbl_guc_ver9_14/kbl_guc_ver9_14.bin
-rw-r--r--  root   root   142656  2017-10-26  /lib/firmware/i915/kbl_guc_ver9_14.bin
$ diff /home/rick/Downloads/kbl_guc_ver9_14/kbl_guc_ver9_14.bin /lib/firmware/i915/kbl_guc_ver9_14.bin
# Blank line appears here signifying no differences from previous version
$ sudo cp /home/rick/Downloads/kbl_guc_ver9_14/kbl_guc_ver9_14.bin /lib/firmware/i915
-rw-r--r--  root   root   142656  2018-05-26  /lib/firmware/i915/kbl_guc_ver9_14.bin
Use the locate command below in place of llocate.
February 14, 2017 - Intel has released drivers
As per this bug report today (W: Possible missing firmware /lib/firmware/i915/kbl_guc_ver9_14.bin for module i915) Intel has released the required Kabylake and Broxton drivers on their (https://01.org/linuxgraphics/downloads/firmware) web page:
Intel Graphics for Linux Drivers
Download the missing drivers for Kabylake (GuC - Ver 9.14) and (DMC - Ver 1.01) and Broxton (GuC - Ver 8.7). These are in .tar.gz and .tar.bz2 format.
Install drivers in "tar" format
Although you can run the install.sh scripts these instructions are the easiest.
Change to the download directory and verify files are there:
:~$ cd Downloads
:~/Downloads$ ll tar -rw-rw-r-- 1 rick rick 69329 Feb 14 21:05 bxtgucver87.tar.gz -rw-rw-r-- 1 rick rick 4338 Feb 14 21:06 kbldmcver101.tar.bz2 -rw-rw-r-- 1 rick rick 70402 Feb 14 21:06 kblgucver914.tar.gz
Extract the compressed tar files:
:~/Downloads$ tar -zxvf bxtgucver87.tar.gz
firmware/bxt/guc/bxt_guc_ver8_7/
firmware/bxt/guc/bxt_guc_ver8_7/install.sh
firmware/bxt/guc/bxt_guc_ver8_7/ReleaseNotes.txt
firmware/bxt/guc/bxt_guc_ver8_7/bxt_guc_ver8_7.bin
:~/Downloads$ tar -xjvf kbldmcver101.tar.bz2 kbl_dmc_ver1_01/ kbl_dmc_ver1_01/kbl_dmc_ver1_01.bin kbl_dmc_ver1_01/install.sh kbl_dmc_ver1_01/ReleaseNotes.txt
:~/Downloads$ tar -zxvf kblgucver914.tar.gz firmware/kbl/guc/kbl_guc_ver9_14/ firmware/kbl/guc/kbl_guc_ver9_14/install.sh firmware/kbl/guc/kbl_guc_ver9_14/kbl_guc_ver9_14.bin firmware/kbl/guc/kbl_guc_ver9_14/ReleaseNotes.txt
Copy the files and update initramfs
:~/Downloads$ sudo cp -t /lib/firmware/i915/ firmware/bxt/guc/bxt_guc_ver8_7/bxt_guc_ver8_7.bin kbl_dmc_ver1_01/kbl_dmc_ver1_01.bin firmware/kbl/guc/kbl_guc_ver9_14/kbl_guc_ver9_14.bin
:~/Downloads$ sudo update-initramfs -u
update-initramfs: Generating /boot/initrd.img-4.9.9-040909-generic
Notice the error (warning) messages are gone!
Remove work files
:~/Downloads$ rm -r firmware kbl_dmc_ver1_01 *.tar.*
Historical (Original) Post for reference
I've had two warning messages on missing i915 drivers for Kernel's 4.6.3, 4.7.1, 4.7.2, 4.7.3 and 4.7.5. I've ignored them and things have been fine with my HD4000 Intel Integrated Graphics. I wish the same thing could be said about Nvidia and Nouvaeu.
As one answer in your link stated you can go to Intel's website to get most up-to-date Linux Graphics drivers at: intel-linux-graphics-firmwares. However when I read that site a few weeks ago I was concerned with all the possible things that can go wrong under different scenarios so I opted out.
Did you install 4.8 release candidate 6 from September 24th? That's the most current in Ubuntu I believe. You don't have to answer but I'm curious why you went with 4.8 instead of 4.7.5, ie what the differences are you need to fix things.
Edit - October 19, 2016
Now using kernel version 4.8.1 (real version and not release candidate) for over a week and things are working nicely. This is under Ubuntu 16.04 though. Ubuntu 16.10 was released October 13th and it is using Kernel version 4.8.0 I believe.
It's not my plan to keep updating this answer but I wanted to lay to rest the inference that 4.8 release candidates might have problems. The real version does not.
Edit - February 2, 2017
Now running Kernel version 4.9.5 mainline version which at this time Ubuntu 16.04 has updated it's kernel to 4.4.0-59. Intel changed it's link for Intel Graphics for Linux drivers and I updated the new link above.
Questions still remain about the warning messages generated by sudo update-initramfs -u when Kernel version > 4.8 (Ubuntu 16.10 and Ubuntu 17.04):
As stated in the bug report (bugs.launchpad.net - linux firmware bug) the drivers simply do not exist and will not until a future chip called "kaby lake" is released.
Make the warning messages go away
To make the warning message go away I did the following:
$ sudo cp assembly/hello /lib/firmware/i915/kbl_dmc_ver1_01.bin
$ sudo cp assembly/hello /lib/firmware/i915/kbl_guc_ver9_14.bin
$ sudo cp assembly/hello /lib/firmware/i915/bxt_guc_ver8_7.bin
update-initramfs: Generating /boot/initrd.img-4.9.5-040905-generic
Voila! No more warning messages.
The program "hello" is a 504 byte assembler program that says "Hello World!". You can copy any small executable to the firmware binaries given in the error messages. When Intel eventually releases them the software updater will replace them with the real versions.
How to navigate Intel Graphics for Linux website
It was asked via comments how to navigate within the the new Intel website (01.org - Linux Graphics Downloads) which presents this screen:
Intel Graphics for Linux 1
Type Ubuntu 16.04 into the search field and click the Filter button.
For Ubuntu 16.10 select the first result. In our case Ubuntu 16.04 select the second result INTEL GRAPHICS UPDATE TOOL FOR LINUX* OS V2.0.2 and this screen appears:
Intel Graphics for Linux 2
In my case I selected Ubuntu 16.04 64-bit which downloaded the file intel-graphics-update-tool_2.0.2_amd64.deb to my ~/Downloads directory.
The next step is to open the terminal and use:
cd Downloads
sudo dpkg -i intel*.deb
NOTE: Intel uses the ancients ttf font and your installation will fail if it's not on your system. At this point you need to use:
sudo apt -f install
sudo apt update
sudo apt upgrade
Now you can run the Intel Graphics for Linux Updater tool as this screen shows:
Intel Graphics for Linux 3
Add Intel signatures for Ubuntu
During apt-get update you can see warning / error messages like this:
W: GPG error: https://download.01.org/gfx/ubuntu/16.04/main xenial InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 56A3DEF863961D39
E: The repository 'https://download.01.org/gfx/ubuntu/16.04/main xenial InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
You'll need to add Intel's signatures using:
wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg-4 -O - | \
sudo apt-key add -
Then update in Ubuntu:
sudo apt update
sudo apt upgrade
You can download the missing Kernel Firmware from the Intel Website https://01.org/linuxgraphics/downloads/firmware
  1. Download the required files
  2. Expand the files using tar -xvf
  3. Install the drivers using sudo bash ./install --install
Repeat for all the mentioned firmwares and then reboot
Sarvex
  • 199
Intel have changed the site again, now redirecting to git.kernel.org.
Look at your warnings using a terminal window (terminal, PuTTY, etc. or on the local machine) then for each one click the link in Intel's git page using a web browser (which brings up a hex dump of the file), copy the link location from the plain button above the dump, go back to the terminal and wget this link.
Once you've got the files corresponding to each warning, cp or sudo cp them to /lib/firmware/i915.
Zanna
  • 72,312
I got it and fixed it with testing.
After each command try reboot to know if no more commands needed.
Test if this works. Both or one of packages
sudo apt install firmware-b43-installer
It also installs and uses b43-fwcutter
Maybe some need not that but
sudo apt install firmware-b43legacy-installer
Then
modprobe b43
I think this one fixed it, in case after reboot doesnt work.
maybe again after reboot can check- errors for some other drivers showing, but your driver will be already installed
sudo update-initramfs -u -k all
From my testing in
https://askubuntu.com/a/1387293/9550
Kangarooo
  • 5,223
I was getting these "missing firmware /lib/firmware/i915/...file" messages after an update. My system didn't even have a /lib/firmware/i915 directory. And all operations seemed normal.
Throwing caution to the winds and having a recent full backup I decided I'd try creating bogus null files that the update-initramfs process was complaining about. I copied its error messages to a temporary file (e.g. mytempfile and using one of my text editors (think vi, mcedit, sed, etc.) changed the lines from e.g. W: Possible missing firmware /lib/firmware/i915/bxt_dmc_ver1_07.bin for module i915
to
sudo touch /lib/firmware/i915/bxt_dmc_ver1_07.bin for each erroring .bin file.
I then created the neccessary directory:
sudo mkdir /lib/firmware/i915
And sourced my tempory file: source mytempfile
Then generated a new intramfs: sudo update-initramfs -u
And observed no more error messages about missing i915 .bin files.
A test reboot and everything came up OK.
This process will create a null zero-sized file for each of the missing .bin files. When/If an update is pushed which contains new updated .bin files, it will overwrite the null files we just created.
Some words of caution:
  1. Have a backup.
  2. Only do this once you have fully updated your system
  3. Verify you don't have any problems which may interfere.
  4. This worked for me. YMMV. And this workaround is probably not 'approved' by the poobahs.
(Cross-posted because I hate seeing questions answered with only a link to an answer in a different post...)
dave58
  • 210
Solution
  1. Install or update the linux-firmware package first
    sudo apt install linux-firmware
  2. Check to make sure no more firmware is missing
  3. If any firmware is still missing, follow WinEunuuchs2Unix's answer to install it manually
Details
In the past, I solved this problem my manually downloading the missing firmware and copying it into place as WinEunuuchs2Unix has suggested.
I saw this message just today:
update-initramfs: Generating /boot/initrd.img-6.2.0-31-generic
W: Possible missing firmware /lib/firmware/i915/dg2_huc_gsc.bin for module i915
But I noticed after updating linux-firmware it went away. Sure enough, that file is in the package:
$ apt-file list linux-firmware | grep /lib/firmware/i915/dg2_huc_gsc.bin
linux-firmware: /lib/firmware/i915/dg2_huc_gsc.bin
In fact, there are over a hundred files for i915 alone:
 apt-file list linux-firmware | grep i915 | wc -l
123
And thousands of firmware files in total:
$ apt-file list linux-firmware | grep /lib/firmware | wc -l
3069
Maybe it's possible that firmware could be missing if it hasn't been added to linux-firmware yet, but at least on my machine at the moment (with an 11th gen Intel CPU), all of the firmware I need is in linux-firmware.
bmaupin
  • 5,371
