I've had to remove my graphics card for some time and I've just connected my screen to the Gigabyte Z390 AORUS Pro motherboard output HDMI. But I can't change the monitor resolution to 2k (1440p), even though the Gigabyte spec states the onboard graphics has 1 x HDMI port, supporting a maximum resolution of 4096x2160@30 Hz, Support for HDMI 1.4 version and HDCP 2.2, and the CPU's specs for UHD630 graphics onboard calls for 4096x2304 .
I've followed steps here but it's not working, just changed the Login screen to 2k resolution.
Also I've copied the bin that describes this post, without any result.
Some outputs from related commands.
xrandr:
Screen 0: minimum 8 x 8, current 720 x 576, maximum 32767 x 32767
HDMI1 connected primary 720x576+0+0 (normal left inverted right x axis y axis) 530mm x 300mm
   720x576       50.00*
   720x480       60.00    59.94
   640x480       60.00    59.94
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
uname -a:
Linux cristian 4.15.0-55-generic #60-Ubuntu SMP Tue Jul 2 18:22:20 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
lspci:
00:00.0 Host bridge: Intel Corporation Device 3e30 (rev 0a)
00:02.0 VGA compatible controller: Intel Corporation Device 3e98
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10)
00:1b.0 PCI bridge: Intel Corporation Device a340 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Device a338 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port 9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a305 (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
lshw | grep -A5 "Moth":
description: Motherboard
       product: Z390 AORUS PRO-CF
       vendor: Gigabyte Technology Co., Ltd.
       physical id: 0
       version: x.x
       serial: Default string
In my Windows partition, all works perfectly without any configuration so I suppose that all is OK in BIOS configuration.
K7AAY
  • 17,705
Finally I installed Ubuntu Budgie 19.04 as @K7AAY recommended and all works fine.
