Several users (one, two, three, four, five) have reported that Intel graphics cards cause severe screen tearing/flickering on Ubuntu >= 16.10. The oft-proposed "solution" is to add the boot parameter i915.enable_rc6=0.
However, while fixing the screen flickering/tearing, this "solution" causes the fan to run constantly (as in it never, ever turns off) and at an excessively high speed. I am posting this question to see if anyone has a remedy to the fan issue (or, in the alternative, to the flickering/tearing issue but without causing the fan issue).
For completeness, I am running Ubuntu 16.10/17.04/17.10 using kernel 4.11.0-10-generic on a Lenovo 910 (Kabylake) and my graphics card is VGA compatible controller: Intel Corporation Device 5916 (rev 02).
Note: I just confirmed that this problem still exists with the upstream kernel (v4.13.0-041300rc4). Reverting the kernel to the 16.04 LTS kernel fixes the screen tearing, but that is just a workaround. I recently (09.03.2017) tried the default Debian install with kernel 4.9.0-3-amd64, and there is no screen flickering (though the screen is rotated 90 degrees).
Note 2: Using the boot parameter i915.enable_rc6=0 leads to system degredation over extended use. I tried to watch a streaming video for 3 hours and the machine starting acting sluggish and unresponsive.
Note 3: I filed a bug report.
Note 4: This may not be relevant, but the screen tearing stops completely when the pointing device (trackpad) or the keyboard is in use.
