29
I recently added Cairo Dock to my GNOME Shell in 11.10. Cairo Dock is GREAT, but I'm left with one little problem that I'd like to fix: after installing Cairo Dock, LightDM includes two extraneous entries to non-working desktops. (The entries to working desktops remain unaffected, so I guess I could just ignore the extraneous entries, but...)
So I'd like to remove/edit the extraneous entries in LightDM. I've looked and looked for discussions on how to do so, but haven't had much luck.
Any suggestions on how to go about editing the login menu in 11.10?
fossfreedom
  • 174,526
Lexalt
  • 413
The list of sessions is defined by the .desktop files in the folder /usr/share/xsessions
Lets remove GNOME Classic
In a terminal:
cd /usr/share/xsessions
sudo mv gnome-classic.desktop gnome-classic.desktop.backup
This renames the gnome-classic desktop file
Logout - the new list of sessions will look like:
fossfreedom
  • 174,526
23
Your package maintainers will be proud of you if you do it as follows:
sudo mkdir /usr/share/xsessions/hidden
sudo dpkg-divert --rename \
      --divert /usr/share/xsessions/hidden/gnome-classic.desktop \
      --add /usr/share/xsessions/gnome-classic.desktop
What this does is to instruct the package manager to remember a new location for the file. This has several advantages over the other answers:
  • It guarantees a future package install/upgrade won't revert your change
  • It works with other display managers (lxdm for example lists .backup entries)
  • You can revert it easily if you change your mind with:
    sudo dpkg-divert --rename --remove /usr/share/xsessions/gnome-classic.desktop
12
  • Open terminal with Ctrl-Alt-T
  • cd /usr/share/xsessions
  • ls will show you, for example:
    awesome.desktop  gnome-shell.desktop  ubuntu.desktop
    gnome.desktop    ubuntu-2d.desktop
  • Use sudo rm lubuntu.desktop (or whatever) to remove the ones you don't need any longer.
  • Logout and you should see the changes -- if not, reboot and you will see them.
ish
  • 141,990
