Thanks to the answers at How to remove xubuntu-desktop?, I know how to remove the Xubuntu desktop.
But I am concerned that removing Xubuntu from my Ubuntu install might affect or harm the Unity desktop environment. Is this concern of mine valid?
Welshmike
  • 197
The answer from the question you refrence links to this site, http://www.psychocats.net/ubuntu/pureubuntu
In that site it states-
These removal commands were created based on what Kubuntu, Xubuntu, etc. packages were added to a default Ubuntu installation. It's possible that the commands might remove some other packages you have since added to the default and want to keep. If that's the case, keep track of which packages those are and reinstall them. Theoretically, your settings should still be there. I am not responsible for any damage you do to your *buntu installation. If you're worried about breaking anything, do a full back up of your *buntu installation.
So, yes the commands may cause something to go wrong.
For example there may be programs that you use that might just happen to be installed by default in Xubuntu, that you may want to keep, in the command for removing everything installed by Xubuntu
sudo apt-get remove abiword abiword-common abiword-plugin-grammar abiword-plugin-mathview alacarte bison blueman brltty-x11 catfish docbook-xml exo-utils flex fonts-droid gigolo gimp gimp-data gmusicbrowser gnome-desktop-data gnome-system-tools gnome-time-admin gnumeric gnumeric-common gnumeric-doc gstreamer0.10-gnomevfs gthumb gthumb-data gtk2-engines-pixbuf indicator-application-gtk2 indicator-messages-gtk2 indicator-sound-gtk2 indicator-status-provider-pidgin leafpad libabiword-2.9 libao-common libao4 libaudio-scrobbler-perl libbabl-0.0-0 libbison-dev libcolamd2.7.1 libconfig-inifiles-perl libdigest-crc-perl libencode-locale-perl libept1.4.12 libexo-1-0 libexo-common libexo-helpers libfile-listing-perl libfl-dev libfont-afm-perl libgarcon-1-0 libgarcon-common libgdome2-0 libgdome2-cpp-smart0c2a libgegl-0.0-0 libgimp2.0 libglade2-0 libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra libgoffice-0.8-8 libgoffice-0.8-8-common libgsf-1-114 libgsf-1-common libgstreamer-perl libgtk2-notify-perl libgtk2-trayicon-perl libgtkmathview0c2a libgtkspell0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl libid3tag0 libido-0.1-0 libilmbase6 libio-socket-inet6-perl libio-socket-ssl-perl libjavascriptcoregtk-1.0-0 libjpeg-progs libjpeg-turbo-progs libkeybinder0 liblaunchpad-integration1 liblink-grammar4 libloudmouth1-0 liblwp-mediatypes-perl liblwp-protocol-https-perl libmad0 libmailtools-perl libnet-dbus-perl libnet-http-perl libnet-ssleay-perl liboobs-1-5 libopenexr6 libotr2 libots0 librarian0 libsexy2 libsocket6-perl libtagc0 libthunarx-2-0 libtidy-0.99-0 libtie-ixhash-perl libtimedate-perl libtumbler-1-0 libunique-1.0-0 liburi-perl libvte-common libvte9 libwebkitgtk-1.0-0 libwebkitgtk-1.0-common libwv-1.2-4 libwww-perl libwww-robotrules-perl libxfce4ui-1-0 libxfce4util-bin libxfce4util-common libxfce4util4 libxfcegui4-4 libxfconf-0-2 libxml-parser-perl libxml-twig-perl libxml-xpath-perl libxss1 lightdm-gtk-greeter link-grammar-dictionaries-en linux-headers-3.2.0-24 linux-headers-3.2.0-24-generic linux-headers-generic lp-solve m4 mpg321 orage parole pastebinit pavucontrol pidgin pidgin-data pidgin-libnotify pidgin-microblog pidgin-otr plymouth-theme-xubuntu-logo plymouth-theme-xubuntu-text python-configobj python-glade2 python-gmenu rarian-compat ristretto screensaver-default-images sgml-data shimmer-themes synaptic system-tools-backends tcl8.5 thunar thunar-archive-plugin thunar-data thunar-media-tags-plugin thunar-volman ttf-droid ttf-lyx tumbler tumbler-common xchat xchat-common xfburn xfce-keyboard-shortcuts xfce4-appfinder xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-indicator-plugin xfce4-mailwatch-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-notifyd xfce4-panel xfce4-places-plugin xfce4-power-manager xfce4-power-manager-data xfce4-quicklauncher-plugin xfce4-screenshooter xfce4-session xfce4-settings xfce4-systemload-plugin xfce4-taskmanager xfce4-terminal xfce4-utils xfce4-verve-plugin xfce4-volumed xfce4-weather-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfdesktop4-data xfwm4 xscreensaver xscreensaver-data xscreensaver-gl xubuntu-artwork xubuntu-default-settings xubuntu-desktop xubuntu-docs xubuntu-icon-theme xubuntu-wallpapers && sudo apt-get install ubuntu-desktop && sudo /usr/lib/lightdm/lightdm-set-defaults -g unity-greeter
One that you may want to keep would would be gimp if you are using it, so look through the list so you know what it is removing.
Mateo
  • 8,152
As explained in Can changing desktops environments affect my programs/personal data?, installing (or removing) a given desktop environment shouldn't affect any other desktop environment that you currently have on your system. It's just about installing/removing a bunch of packages, which apt ensures are independent of each other (two different packages cannot install the exact same file in the exact same path).
This said, it depends on how you go about the uninstall procedure. If for example you consider that lightdm is part of Xubuntu and remove that (don't!), and you have no other display manager available, then you can render your system unusable. So if you follow other answers that suggest removing a very specific list of packages, make sure to check each manually that there isn't anything that could be crucial to your system.
Now for an actual safe way (as far as I go) of removing Xfce, if I wanted to do that on my system I would proceed as follows:
root@malou-laptop:/home/liv# apt-get remove libxfce* libexo-common xfce*
Reading package lists... Done
Building dependency tree
Note, selecting 'libxfcegui4-4' for regex 'libxfce*'
Note, selecting 'libxfconf-0-dev' for regex 'libxfce*'
Note, selecting 'libxfce4ui-1-dbg' for regex 'libxfce*'
Note, selecting 'libxfce4ui-1-dev' for regex 'libxfce*'
Note, selecting 'libxfce4util-bin' for regex 'libxfce*'
Note, selecting 'libxfce4util-dev' for regex 'libxfce*'
Note, selecting 'libxfce4util-1' for regex 'libxfce*'
Note, selecting 'libxfce4ui-utils-dbg' for regex 'libxfce*'
Note, selecting 'libxfcegui4-4-dbg' for regex 'libxfce*'
Note, selecting 'libxfce4util6-dbg' for regex 'libxfce*'
Note, selecting 'libxfce4util6-dev' for regex 'libxfce*'
Note, selecting 'libxfce4ui-2-dbg' for regex 'libxfce*'
Note, selecting 'libxfce4util4' for regex 'libxfce*'
Note, selecting 'libxfce4util6' for regex 'libxfce*'
Note, selecting 'libxfce4ui-2-dev' for regex 'libxfce*'
Note, selecting 'libxfce4util-common' for regex 'libxfce*'
Note, selecting 'libxfce4menu-0.1-0' for regex 'libxfce*'
Note, selecting 'libxfconf-0-2-dbg' for regex 'libxfce*'
Note, selecting 'libxfce4ui-common' for regex 'libxfce*'
Note, selecting 'libxfce4ui-1-0' for regex 'libxfce*'
Note, selecting 'libxfce4ui-2-0' for regex 'libxfce*'
Note, selecting 'libxfce4ui-utils' for regex 'libxfce*'
Note, selecting 'libxfce4util4-dbg' for regex 'libxfce*'
Note, selecting 'libxfconf-0-2' for regex 'libxfce*'
Note, selecting 'libxfcegui4-dev' for regex 'libxfce*'
Note, selecting 'xfce4-equake-plugin' for regex 'xfce*'
Note, selecting 'libxfcegui4-4' for regex 'xfce*'
Note, selecting 'xfce4-genmon-plugin' for regex 'xfce*'
Note, selecting 'xfce4-mcs-plugins' for regex 'xfce*'
Note, selecting 'libxfconf-0-dev' for regex 'xfce*'
Note, selecting 'xfce4-messenger-plugin' for regex 'xfce*'
Note, selecting 'xfce4-time-out-plugin' for regex 'xfce*'
Note, selecting 'libxfce4ui-1-dbg' for regex 'xfce*'
Note, selecting 'xfce4-embed-plugin' for regex 'xfce*'
Note, selecting 'xfce4-mpc-plugin' for regex 'xfce*'
Note, selecting 'libxfce4ui-1-dev' for regex 'xfce*'
Note, selecting 'xfce4-terminal-dbg' for regex 'xfce*'
Note, selecting 'libxfce4util-bin' for regex 'xfce*'
Note, selecting 'libxfce4util-dev' for regex 'xfce*'
Note, selecting 'xfce4-dbg' for regex 'xfce*'
Note, selecting 'desktopnova-module-xfce' for regex 'xfce*'
Note, selecting 'xfce4-xkb-plugin' for regex 'xfce*'
Note, selecting 'xfce4-nofityd' for regex 'xfce*'
Note, selecting 'xfce4-notifyd' for regex 'xfce*'
Note, selecting 'xfce4-volumed' for regex 'xfce*'
Note, selecting 'glade-xfce' for regex 'xfce*'
Note, selecting 'libxfce4util-1' for regex 'xfce*'
Note, selecting 'xfce4-verve-plugin' for regex 'xfce*'
Note, selecting 'libxfce4ui-utils-dbg' for regex 'xfce*'
Note, selecting 'xfce4-panel' for regex 'xfce*'
Note, selecting 'xfce4-goodies' for regex 'xfce*'
Note, selecting 'xfce4-cpufreq-plugin' for regex 'xfce*'
Note, selecting 'xfce4-taskmanager' for regex 'xfce*'
Note, selecting 'xfce4-mailwatch-plugin' for regex 'xfce*'
Note, selecting 'libxfcegui4-4-dbg' for regex 'xfce*'
Note, selecting 'remmina-xfce' for regex 'xfce*'
Note, selecting 'xfce4' for regex 'xfce*'
Note, selecting 'xfce4-notes-plugin' for regex 'xfce*'
Note, selecting 'xfce4-timer-plugin' for regex 'xfce*'
Note, selecting 'xfce-theme-manager' for regex 'xfce*'
Note, selecting 'xfce4-vala-dev' for regex 'xfce*'
Note, selecting 'libxfce4util6-dbg' for regex 'xfce*'
Note, selecting 'xfce4-appfinder' for regex 'xfce*'
Note, selecting 'xfce4-radio-plugin' for regex 'xfce*'
Note, selecting 'xfce4-panel-dbg' for regex 'xfce*'
Note, selecting 'libxfce4util6-dev' for regex 'xfce*'
Note, selecting 'xfce-theme-manager-dbg' for regex 'xfce*'
Note, selecting 'libxfce4ui-2-dbg' for regex 'xfce*'
Note, selecting 'xfce4-battery-plugin' for regex 'xfce*'
Note, selecting 'xfce4-panel-dev' for regex 'xfce*'
Note, selecting 'xfce4-composite-editor' for regex 'xfce*'
Note, selecting 'libxfce4util4' for regex 'xfce*'
Note, selecting 'libxfce4util6' for regex 'xfce*'
Note, selecting 'libxfce4ui-2-dev' for regex 'xfce*'
Note, selecting 'xfce-keyboard-shortcuts' for regex 'xfce*'
Note, selecting 'xfce4-cddrive-plugin' for regex 'xfce*'
Note, selecting 'xfce4-volstatus-icon' for regex 'xfce*'
Note, selecting 'libxfce4util-common' for regex 'xfce*'
Note, selecting 'xfce4-dockbarx-plugin' for regex 'xfce*'
Note, selecting 'libxfce4menu-0.1-0' for regex 'xfce*'
Note, selecting 'xfce4-weather-plugin' for regex 'xfce*'
Note, selecting 'xfce4-netload-plugin' for regex 'xfce*'
Note, selecting 'xfce4-session-dbg' for regex 'xfce*'
Note, selecting 'xfce4-indicator-plugin' for regex 'xfce*'
Note, selecting 'xfce4-wavelan-plugin' for regex 'xfce*'
Note, selecting 'libxfconf-0-2-dbg' for regex 'xfce*'
Note, selecting 'xfce4-notes' for regex 'xfce*'
Note, selecting 'xfce4-screenshooter-plugin' for regex 'xfce*'
Note, selecting 'xfce4-xfapplet-plugin' for regex 'xfce*'
Note, selecting 'xfce-theme-manager-examples' for regex 'xfce*'
Note, selecting 'xfce4-systemload-plugin' for regex 'xfce*'
Note, selecting 'xfce4-eyes-plugin' for regex 'xfce*'
Note, selecting 'libxfce4ui-common' for regex 'xfce*'
Note, selecting 'xfce4-diskperf-plugin' for regex 'xfce*'
Note, selecting 'libxfce4ui-1-0' for regex 'xfce*'
Note, selecting 'xfce4-settings' for regex 'xfce*'
Note, selecting 'libxfce4ui-2-0' for regex 'xfce*'
Note, selecting 'gtk3-engines-xfce' for regex 'xfce*'
Note, selecting 'xfce4-fsguard-plugin' for regex 'xfce*'
Note, selecting 'xfce4-cpugraph-plugin' for regex 'xfce*'
Note, selecting 'xfce4-datetime-plugin' for regex 'xfce*'
Note, selecting 'libxfce4ui-utils' for regex 'xfce*'
Note, selecting 'xfce4-artwork' for regex 'xfce*'
Note, selecting 'xfce4-dev-tools' for regex 'xfce*'
Note, selecting 'xfce4-smartbookmark-plugin' for regex 'xfce*'
Note, selecting 'xfce4-power-manager' for regex 'xfce*'
Note, selecting 'xfce4-power-manager-data' for regex 'xfce*'
Note, selecting 'xfce4-whiskermenu-plugin' for regex 'xfce*'
Note, selecting 'gtk2-engines-xfce' for regex 'xfce*'
Note, selecting 'xfce4-mcs-manager' for regex 'xfce*'
Note, selecting 'libxfce4util4-dbg' for regex 'xfce*'
Note, selecting 'xfce4-quicklauncher-plugin' for regex 'xfce*'
Note, selecting 'xfce4-power-manager-plugins' for regex 'xfce*'
Note, selecting 'xfce4-linelight-plugin' for regex 'xfce*'
Note, selecting 'xfce4-utils' for regex 'xfce*'
Note, selecting 'xfce4-mixer-alsa' for regex 'xfce*'
Note, selecting 'xfce4-terminal' for regex 'xfce*'
Note, selecting 'xfconf' for regex 'xfce*'
Note, selecting 'xfce4-mount-plugin' for regex 'xfce*'
Note, selecting 'xfce4-session' for regex 'xfce*'
Note, selecting 'xfce4-sensors-plugin' for regex 'xfce*'
Note, selecting 'xfce4-screenshooter' for regex 'xfce*'
Note, selecting 'libxfconf-0-2' for regex 'xfce*'
Note, selecting 'xfce4-hdaps' for regex 'xfce*'
Note, selecting 'xfce4-wmdock-plugin' for regex 'xfce*'
Note, selecting 'xfce4-cellmodem-plugin' for regex 'xfce*'
Note, selecting 'xfce4-clipman' for regex 'xfce*'
Note, selecting 'xfce4-places-plugin' for regex 'xfce*'
Note, selecting 'libxfcegui4-dev' for regex 'xfce*'
Note, selecting 'xfce4-mixer' for regex 'xfce*'
Note, selecting 'xfce4-clipman-plugin' for regex 'xfce*'
Note, selecting 'gwallpapers-module-xfce' for regex 'xfce*'
Note, selecting 'xfce4-mixer-oss' for regex 'xfce*'
Note, selecting 'xfce4-vala' for regex 'xfce*'
Note, selecting 'xfce4-dict' for regex 'xfce*'
Package desktopnova-module-xfce is not installed, so not removed
Package libxfce4util4-dbg is not installed, so not removed
Package xfce4-utils is not installed, so not removed
Package xfce4-dockbarx-plugin is not installed, so not removed
Package xfce-theme-manager-dbg is not installed, so not removed
Package xfce-theme-manager-examples is not installed, so not removed
Package xfce4-radio-plugin is not installed, so not removed
Package xfce4-messenger-plugin is not installed, so not removed
Package xfce4-mpc-plugin is not installed, so not removed
Package xfce4-cellmodem-plugin is not installed, so not removed
Package xfce4-wmdock-plugin is not installed, so not removed
Package xfce4-eyes-plugin is not installed, so not removed
Package xfce4-panel-dbg is not installed, so not removed
Package libxfcegui4-4-dbg is not installed, so not removed
Package glade-xfce is not installed, so not removed
Package libxfconf-0-2-dbg is not installed, so not removed
Package xfce4-linelight-plugin is not installed, so not removed
Package xfce4-hdaps is not installed, so not removed
Package xfce4-dbg is not installed, so not removed
Package xfce4-terminal-dbg is not installed, so not removed
Package xfce4-session-dbg is not installed, so not removed
Package libxfce4util6-dbg is not installed, so not removed
Package gtk3-engines-xfce is not installed, so not removed
Package libxfce4ui-1-dbg is not installed, so not removed
Package libxfce4ui-utils-dbg is not installed, so not removed
Package libxfce4ui-2-dbg is not installed, so not removed
Package xfce4-volstatus-icon is not installed, so not removed
Package libxfce4menu-0.1-0 is not installed, so not removed
The following extra packages will be installed:
  libpixman-1-0 libpixman-1-dev notify-osd
The following packages will be REMOVED:
  blueman exo-utils gnome-power-manager gtk2-engines-xfce libexo-1-0
  libexo-1-dev libexo-common libgarcon-1-0 libgarcon-1-0-dev libthunar-vfs-1-2
  libthunarx-2-0 libxfce4ui-1-0 libxfce4ui-1-dev libxfce4ui-2-0
  libxfce4ui-2-dev libxfce4ui-common libxfce4ui-utils libxfce4util-bin
  libxfce4util-common libxfce4util-dev libxfce4util4 libxfce4util6
  libxfcegui4-4 libxfcegui4-dev libxfconf-0-2 libxfconf-0-dev orage parole
  ristretto squeeze thunar thunar-archive-plugin thunar-dropbox-plugin
  thunar-gtkhash thunar-media-tags-plugin thunar-sendto-clamtk thunar-volman
  xfburn xfce-keyboard-shortcuts xfce-theme-manager xfce4 xfce4-appfinder
  xfce4-artwork xfce4-battery-plugin xfce4-clipman xfce4-clipman-plugin
  xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin
  xfce4-dev-tools xfce4-dict xfce4-diskperf-plugin xfce4-embed-plugin
  xfce4-equake-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies
  xfce4-indicator-plugin xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin
  xfce4-panel xfce4-panel-dev xfce4-places-plugin xfce4-power-manager
  xfce4-power-manager-data xfce4-power-manager-plugins
  xfce4-quicklauncher-plugin xfce4-screenshooter xfce4-screenshooter-plugin
  xfce4-sensors-plugin xfce4-session xfce4-settings xfce4-smartbookmark-plugin
  xfce4-time-out-plugin xfce4-timer-plugin xfce4-vala xfce4-vala-dev
  xfce4-verve-plugin xfce4-volumed xfce4-wavelan-plugin xfce4-weather-plugin
  xfce4-whiskermenu-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfswitch-plugin
  xfwm4 xfwm4-themes xubuntu-desktop
The following NEW packages will be installed:
  notify-osd
The following packages will be upgraded:
2 upgraded, 1 newly installed, 97 to remove and 125 not upgraded.
Need to get 675 kB of archives.
After this operation, 90.7 MB disk space will be freed.
Do you want to continue [Y/n]? n
Abort.
Now before you go ahead and say "yes" above, look closely at the list of packages, identify those that you wouldn't want removed (say, blueman and Thunar), make a list. After the removal is complete, reinstall those packages:
apt-get install blueman thunar
That's as safe as it gets to removing Xfce and, to come back to your original question, should NOT affect an existing installation of Unity. As for remaining bits of Xubuntu, follow the other answers and evaluate each package removal individually.
landroni
  • 6,011
