When logging in to Xubuntu, I get a selection list of saved sessions, most of them is outdated old stuff.
I hit the delete button in a sportive manner. I tried a click to the left, and just a click to the right - no deletion possible.
I went through system menus and menu sections (and the system section of the menu).
Note: Not related: How to remove session entries from LightDM? or Managing the login screen's sessions list which links to it - they handle session-classes like xubuntu vs. xfce, gnome, kde - not different xfce-sessions.
Note: I want to remove some sessions, not all of them. I don't want to start with the session-list deactivated. I have 5 entries and want to remove 3 of them.
user unknown
  • 6,892
Go to $HOME/.cache/sessions and open the latest file with the name xfce-session-yourdesktopname in a text editor.
All your sessions are listed in the file by name in this format:
[Session: Default]
or
[Session:somename]
Select the entire set of lines from [Session:somename] to the next blank line (including the [Session:somename] line and delete them. Save the file.
Peachy
  • 7,235
  • 40
  • 47
Sagarchalise brought me on the right track, but only half the way.
The place, where to look in Xfce is indeed
I found a lot of files there, including some empty Thunar- files, xfwm4- files and, interesting for us, xfce4-session-asux:0, where asux is the name of my local machine, the hostname.
:0 reminds of the way, the XServer enumerates different instances, which I used rarely, but I used it, so I have a xfce4-session-asux:1 file as well, and it is rather old, but different sessions aren't stored in different files, but in different sections inside the file.
Such a section looks like this:
[Session: 2010]
key1=value1
key2=value2
LastAccess=1315125649
So you can see the name ("2010" in this case) of the session, a bunch of key-value-pairs, and as last these pairs a LastAccess key. It stores the seconds since 1.1.1970 UTC. It's not short and easy to translate it to a human readable date with date or bash arithmetic (or tell me how in the comments). But at least the age in years is worth calculating:
echo $((1315125649/(365*24*60*60)))
41
So it is 41 years after 1.1.1970 (ignoring leap years and daylight saving time, and cutting the result to whole years) which is 2011. The other fields can be computed as well - I prefered to do it with scala by
scala> val d = new java.util.Date (1315125649*1000L)
d: java.util.Date = Sun Sep 04 10:40:49 CEST 2011
So I remove the whole section, and after relogin, this session is vanished from my list of sessions.
update:
I now know the much simpler solution for the date issue, simply put into the shell:
date -d @1315125649
So 4. Sep 10:40:49 CEST 2011
So this can be made into a simple script:
for f in  ~/.cache/sessions/xfce4-session-*
do
   la=$(sed -n -r 's/LastAccess=(.*)/\1/p' "$f")
   echo -e $(date -d @$la) "\t$f"
done
Fr 9. Mär 07:17:13 CET 2018 /home/stefan/.cache/sessions/xfce4-session-tux201t:0 Fr 9. Mär 07:16:03 CET 2018 /home/stefan/.cache/sessions/xfce4-session-tux201t:0.bak
user unknown
  • 6,892
AFAIK most of the display managers handle sessions from .desktop files present in /usr/share/xsessions. I guess renaming it to something else will remove session entries.
E.g.
cd /usr/share/xsessions
mv gnome.desktop gnome.desktop.backup
xfce caches its session in $HOME/.cache/sessions as well as has configurations in $HOME/.config/xfce4-session. You could try viewing those folders as well. I think xubuntu has folders with names xubuntu in place of xfce as it has its own session manager.
sagarchalise
  • 24,306
-1
This is how it goes:
  • Click on Settings manager at the app menu or run xfce4-settings-manager from a terminal
  • Click on 'Session and Startup'
  • Uncheck 'Display chooser on login' on the general tab, 'Session Chooser'
  • Also review the 'Logout Settings' on the same tab.
  • *In session tab, Click 'Clear saved session' *
aquaherd
  • 6,345
