After fresh install of Ubuntu 16.04, i have broken packages and can not install most of applications. I tried from Synaptic "Fix broken packages" but it is not working. An example;
sudo apt-get install steam
Output;
Reading package lists... Done
Building dependency tree
 steam:i386 : Depends: libc6:i386 (>= 2.15) but it is not going to be    installed
          Depends: libstdc++6:i386 (>= 4.3) but it is not going to be installed
          Depends: libx11-6:i386 but it is not going to be installed
          Depends: libudev1:i386 but it is not going to be installed
          Depends: libxinerama1:i386 but it is not going to be installed
          Depends: libtxc-dxtn0:i386
          Depends: libgl1-mesa-dri:i386 but it is not going to be installed
          Depends: libgl1-mesa-glx:i386 but it is not going to be installed
An other example;
sudo apt-get install nvidia-361
Output;
 nvidia-361 : Depends: lib32gcc1 but it is not going to be installed
              Depends: libc6-i386 but it is not going to be installed
There is no output from;
sudo apt-get clean
I tried;
sudo apt-get install -f
Outputs;
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Thanks..
al0s
  • 549
  • 16
16.04 is new and all packages are not ready to use in all servers. Using Main Server to download packages solve my problem.
  1. System Settings
  2. Software & Updates
  3. Select "Main Server" from "Download from" section
al0s
  • 549
  • 16
I had the same issue after enabling foreign architecture for arm :
dpkg --print-foreign-architectures
i386
armvfp
armhf
This prevented apt update to complete fully, it always ended with :
N: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'http://apt.llvm.org/xenial llvm-toolchain-xenial-3.9 InRelease' doesn't support architecture 'armhf'
N: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'http://apt.llvm.org/xenial llvm-toolchain-xenial InRelease' doesn't support architecture 'armhf'
N: Skipping acquire of configured file 'non-free/binary-armhf/Packages' as repository 'http://repository.spotify.com stable InRelease' doesn't support architecture 'armhf'
W: http://ppa.launchpad.net/colingille/freshlight/ubuntu/dists/vivid/Release.gpg: Signature by key 3764AB961B292804CD3474FAEAE2E8E7CB7F5C71 uses weak digest algorithm (SHA1)
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-armhf/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-armhf/Packages  404  Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-proposed/main/binary-armhf/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-armhf/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
While the errors were only for arm, it prevented to install many packages. Removing these architectures with sudo dpkg --remove-architecture armvfp and sudo dpkg --remove-architecture armhf followed by an apt update solved the issues.
I know the OP question is already answered, but the same symptoms happened in my case.
daminetreg
  • 111
