I have a fresh install of Ubuntu Server 16.10 and was hoping to install Mosquitto. When running sudo apt-get install mosquitto, I always get the following error:
Reading package lists... Done
Building dependency tree
 mosquitto : Depends: sysv-rc (>= 2.88dsf-24) but it is not installable or
                      file-rc (>= 0.8.16) but it is not installable
             Depends: libwebsockets3 (>= 1.2) but it is not installable
N: Ignoring file 'index.html' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
I have tried following the instructions on http://mosquitto.org/download by first installing the PPA, using -f to fix the dependency issues, using aptitude instead per this post, changing the download server to Main according to this post and this post, and I get the same results every time.
I've tried manually installing those dependencies, but predictably they all return an error like this:
Package sysv-rc is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  init-system-helpers
E: Package 'sysv-rc' has no installation candidate
And in case there's any question, init-system-helpers is already installed with version 1.45. And I have remembered to use sudo apt-get update and have tried rebooting several times.
I'n not completely new to Ubuntu, but I spent 4+ hours on this last night and just can't figure it out. I haven't even found a single person online with the same issue. Any ideas how I might be able to fix it?
Thank you so much in advance!
It's not the answer I was looking for, but an answer that I found worked was to wipe it and install Ubuntu 16.04. Mosquitto installed with sudo apt-get install mosquitto after that.
I have run into the same problem.
I believe there is something wrong with the ppa. My solution is removing the mosquitto config in /etc/apt/sources.list.d, which means undo the apt-add-repository command. And then install mosquitto from the ubuntu official repo, which version is 1.4.8, depending on libwebsockects7.
The mosquitto from the ppa is version 1.4.9, but it depends on libwebsockets3, which looks much older and has been removed from the official repo. That is why you can not get the deps installed.
aGuegu
  • 101
