I'm trying to install octave on freshly installed Ubuntu 16.04. So I've tried these commands:
sudo apt-add-repository ppa:octave/stable
sudo apt-get update
sudo apt-get install octave
After 'sudo apt-get update', I got this errors and warnings:
Err:9 http://ppa.launchpad.net/octave/stable/ubuntu xenial/main amd64 Packages
404 Not Found
Err:10 http://ppa.launchpad.net/octave/stable/ubuntu xenial/main i386 Packages
404 Not Found
W: The repository 'http://ppa.launchpad.net/octave/stable/ubuntu xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://ppa.launchpad.net/octave/stable/ubuntu/dists/xenial/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://ppa.launchpad.net/octave/stable/ubuntu/dists/xenial/main/binary-i386/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
And after 'sudo apt-get install octave':
octave : Depends: libarpack2 (>= 2.1) but it is not going to be installed
Depends: libcholmod3.0.6 but it is not going to be installed
Depends: liboctave3 (= 4.0.0-3ubuntu9) but it is not going to be installed
Depends: libosmesa6 (>= 10.2~) but it is not going to be installed
Recommends: libopenblas-base but it is not going to be installed or
libatlas3-base but it is not going to be installed
After these, when I try 'sudo apt-get -f install':
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I've tried installing dependencies so that I can compile source code, and similar errors appeared (sudo apt-get install libarpack2):
libarpack2 : Depends: libgfortran3 (>= 4.6) but it is not going to be installed
Depends: liblapack3 but it is not going to be installed or
liblapack.so.3
What can I do now?
