I'm trying to install Ring and have run into dependency problems. I have no idea how to fix this. Would you have any ideas about how to approach this problem? I have attempted sudo apt-get update, sudo apt-get autoremove and sudo apt-get -f install but nothing seemed to help.
>sudo apt-get install ring-gnome
Reading package lists... Done
Building dependency tree
 ring-gnome : Depends: libebook-1.2-16 (>= 3.17) but 3.16.5-1ubuntu3 is to be installed
              Depends: libebook-contacts-1.2-2 (>= 3.16.2) but it is not installable
              Depends: libedataserver-1.2-21 (>= 3.17) but it is not installable
              Depends: libqt5core5a (>= 5.5.1) but 5.4.2+dfsg-2ubuntu9 is to be installed
              Depends: ring-daemon but it is not going to be installed
David Foerster
  • 36,890
  • 56
  • 97
  • 151
d3pd
  • 3,791
Open the terminal and type the following commands:
sudo apt-get install aptitude
sudo aptitude -f install ring-gnome
Read the output and confirm then choose Downgrade package.
GAD3R
  • 3,748
