I'm trying to fix a broken system and work out what dependencies are missing. I ask apt-get about a package:
jon@jon-laptop:/var/log/apt$ sudo apt-get install -s openssh-server
Reading package lists... Done
Building dependency tree
 libumfpack5.7.1 : Depends: libcholmod3.0.6 but it is not going to be installed
 openssh-server : Depends: openssh-client (= 1:7.1p2-2)
                  Depends: openssh-sftp-server but it is not going to be installed
                  Recommends: ssh-import-id but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Ok, so the above says libcholmod3.0.6 is missing. So then I check it with:
jon@jon-laptop:/var/log/apt$ sudo apt-get install -s libcholmod3.0.6
libcholmod3.0.6 is already the newest version (1:4.4.6-1).
libcholmod3.0.6 set to manually installed.
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
So this says it is installed... what's the deal?
thanks!
Jon
  • 171
Try to run
sudo apt-get -f install
I still don't quite get apt-get's output here, but I resolved the underlining issue by changing the Ubuntu mirror I was using.
The old mirror was: http://ubuntu.uhost.hk/
I changed to: http://ftp.cuhk.edu.hk/pub/Linux/ubuntu
It was an official mirror, but stopped being updated (outdated by 2.5 months so far!). I think I may have changed to the mirror after already updating to packages newer than the mirror. Hence why apt-get was so confused (as was I!).
Jon
  • 171
