I have a script that runs via cron to change the desktop wallpaper. I can get it to work by exporting the DISPLAY variable.
But the issue I am concerned about it that the script should work on all systems. How to find the value of DISPLAY set by the X server without using $DISPLAY?
So how can I find the correct value for DISPLAY programmatically. I can get it to work only when DISPLAY=:1. Setting it to ":0" makes the script exit with
No protocol specified
Cannot open display.
You can't for sure. You have to make assumptions.
Pretend you're cron and you're facing the worst case scenario for a second: there are multiple users logged in, and each user is running multiple X sessions. You'll have to guess the user (easy enough, we're executing their crontab) and one of that user's X sessions.
If we want to assume the user is running one and only one X session from a tty, and get that session's $DISPLAY value we can use w:
USER     TTY      FROM             LOGIN@   IDLE   JCPU   PCPU WHAT
user     tty1                      16:32    7:15   0.21s  0.19s -zsh
user     tty2     :1               15:52   48:13   2:17   0.08s /sbin/upstart
user     pts/3    :1               16:19    0.00s  0.66s  0.00s w
For example here I'm logged in on tty1, on tty2 (where I'm running an X session) and on pts/3 (the terminal from which I'm running the command).
With a bit of parsing:
% w $(id -un) | awk 'NF > 7 && $2 ~ /tty[0-9]+/ {print $3; exit}'
:1
So, assuming all the above:
0 0 * * * DISPLAY=$(w $(id -un) | awk 'NF > 7 && $2 ~ /tty[0-9]+/ {print $3; exit}') command
Will make cron execute command with $DISPLAY set to the first X session running in a tty's $DISPLAY value found for the user.
kos
  • 41,268
For a more detailed discussion, refer to https://unix.stackexchange.com/questions/17255/is-there-a-command-to-list-all-open-displays-on-a-machine
I will simply list the relevant information from that answer here:
There seems to be two simple ways to find the X server instances running on your system.
  • w:
    The w command lists all the open displays. You can then use awk to filter out the information you need. The values under FROM are the values corresponding to DISPLAY.
    ashhar@xenon:[/tmp/.X11-unix]
    $ w
    21:18:24 up  3:39,  4 users,  load average: 0.31, 0.27, 0.30
    ashhar   tty2     :1               17:40    3:39m  6:11   0.08s /usr/bin/dunst
    ashhar   pts/0    :1               17:41    3:36m  0.13s  0.05s vim .i3/config
    ashhar   pts/1    :1               18:07    0.00s  1.44s  0.00s w
    ashhar   pts/2    :1               18:15    9:59   0.79s  0.79s bash
  • Local displays correspond to a socket in /tmp/.X11-unix, so we can simply do:
    cd /tmp/.X11-unix && for x in X*; do echo ":${x#X}"; done
Inspired on Ashhar Hasan's answer, I would use (tested on Ubuntu 23.04):
export DISPLAY=$(
  find /tmp/.X11-unix/ -user $USER -type s -printf "%f" -quit | tr X :
By filtering by UID, it will work even in presence of multiple logged-in users.
I have a X11wrap.sh script that lets me run X11 application from system scripts, cron, at etc.
#!/bin/sh
set -eu
export DISPLAY=$( find /tmp/.X11-unix/ -user $USER -type s -printf "%f" -quit | tr X : )
For applications that additionally require DBUS.
export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/$(id -u)/bus
exec "$@"
With it, I can issue the following example, and it will get the X11 system right:
echo X11wrap.sh xeyes | at now
