13
I'm running Ubuntu 15.10 on a new laptop but in order to get proper full support for this hardware I apparently need the 4.4 kernel + a custom patch. See here if you're interested in the details.
I know about the mainline kernel PPAs but my understanding is that they don't come with source. If this is the case, This would seem to eliminate the possibility of using a mainline kernel PPA because I can't patch it. So I've been trying to check out the git source and build it but can't find up to date, relevant instructions.
Can somebody help with instructions for building a 4.4 kernel on 15.10?
Get and compile the mainline kernel, git method:
see also: https://wiki.ubuntu.com/KernelTeam/GitKernelBuild I do things a little different (what else is new?).
Prerequisites (Must):
Step 1 is to apt-get update and apt-get dist-upgrade (i.e. make sure everything is up to date)
Step 2
sudo apt-get install fakeroot build-essential crash kexec-tools makedumpfile kernel-wedge
Step 3
sudo apt-get build-dep linux
EDIT: For 24.04 see this question and answer for modifying the sources.list to avoid this error:
$ sudo apt build-dep linux
Reading package lists... Done
E: You must put some 'deb-src' URIs in your sources.list
Step 4
sudo apt-get install git-core libncurses5 libncurses5-dev libelf-dev asciidoc binutils-dev
EDIT: For 24.04 some of the packages don't exist anymore, and the other needed ones are pulled in by previous commands. Therefore this step is skipped.
Prerequisites as of kernel 4.3:
sudo apt-get install libssl-dev
Step 5 - based on not being able to compile on a new 20.04 server installation 2019.12.02
sudo apt install flex bison
Step 6 - based on not being able to compile kernel 5.13 on a 20.04 server 2021.07.02
sudo apt install zstd
Prerequisites (Optional):
sudo apt-get install git-email git-doc
The git part:
mkdir temp-k-git
cd temp-k-git
git clone   git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
cd linux
Never do stuff in the default master branch. Always make some work area.
git checkout -b k44rc8_stock v4.4-rc8
Steal the Ubuntu kernel configuration file (already installed):
ls -l /boot
cp /boot/config-4.4.0-040400rc8-generic .config
Ubuntu config file has full debugging. Makes an enormous kernel and takes twice as long to compile
scripts/config --disable DEBUG_INFO
but since about 2022.05.28 do this instead:
scripts/config --disable DEBUG_INFO_DWARF5
scripts/config --enable DEBUG_INFO_NONE
Special note as of Kernel 4.4 and if compiling using Ubuntu 14.04 (I don't know about 15.10), with an older version of the c compiler: It can not compile with CONFIG_CC_STACKPROTECTOR_STRONG.
scripts/config --disable CC_STACKPROTECTOR_STRONG
If your version doesn't have LZ4 compression (i.e. 16.04) you need also:
scripts/config --disable KERNEL_LZ4
scripts/config --enable KERNEL_GZIP
Special note as of Kernel 5.12-rc1 one needs to override some newly added certificate stuff.
scripts/config --set-str SYSTEM_TRUSTED_KEYS ""
or
scripts/config --disable SYSTEM_TRUSTED_KEYS
Special note as of Kernel 5.14-rc2 one needs to override some more added certificate stuff.
scripts/config --disable SYSTEM_REVOCATION_KEYS
Compile the kernel:
time make -j9 bindeb-pkg       <<< Suggest use number of CPUs + 1. Use less for some responsiveness to be left for other uses
                               <<< I always time the kernel build.
or
time make -j9 bindeb-pkg LOCALVERSION=-stock    <<< For a localized verion name append
or
time make -j9 olddefconfig bindeb-pkg LOCALVERSION=-stock   <<< To automatically use defaults for any new config stuff (particuarly useful when bisecting the kernel).
or to suppress the reams of output, which might obscure compiler warnings and errors (and I now have 12 CPUs):
time make -s -j13 olddefconfig bindeb-pkg LOCALVERSION=-stock
When the build has completed, install it:
sudo dpkg -i ../linux-headers-4.4.0-rc8-stock_4.4.0-rc8-stock-144_amd64.deb
sudo dpkg -i ../linux-image-4.4.0-rc8-stock_4.4.0-rc8-stock-144_amd64.deb
So, at this point we know the mainline kernel compiles O.K., so move onto the custom kernel. Create a new branch, apply the patches and compile:
$ git checkout -b k44rc8_custom v4.4-rc8
Switched to a new branch 'k44rc8_custom'
$ git am plv6_1_3.patch Applying: cpufreq: intel_pstate: configurable algorithm to get target pstate $ git am plv6_2_3.patch Applying: cpufreq: intel_pstate: account for non C0 time $ git am plv6_3_3.patch Applying: cpufreq: intel_pstate: Account for IO wait time
$ time make -j9 olddefconfig bindeb-pkg LOCALVERSION=-custom
Note that it is on purpose that I do not do a make clean, as it is desirable to save a lot of time by doing an incremental build. The first compile took 21 minutes and 26 seconds, but the next custom compile took only 4 minutes and 43 seconds.
This answer has been tested on a fresh 24.10 installation with kernel 6.12-RC7.
Doug Smythies
  • 16,146
Here is a quick version how to install on Debian-based distributions:
# Install dependencies
sudo apt install -y git build-essential kernel-package fakeroot libncurses5-dev libssl-dev ccache
Clone the kernel
mkdir ~/kernelbuild cd ~/kernelbuild git clone --depth=1 -b linux-5.4.y git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git
^ change kernel branch to the one you're using.
check with uname -r and see the available list at www.kernel.org
cd linux-stable
Build custom kernel
cp /boot/config-uname -r .config # copy config from current kernel yes '' | make oldconfig make clean make -j getconf _NPROCESSORS_ONLN deb-pkg LOCALVERSION=-custom
Install new kernel
sudo dpkg -i ~/kernelbuild/linux-*.deb
Reboot
sudo reboot
Pablo Bianchi
  • 17,371
message
  • 135
If you go to the page http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-rc8-wily you will find a README indicating how to obtain the source files for 4.4rc8
Instructions for build are a little confusing. I've seen several recipes for building the kernels, all a little different. There are several prerequisites: There may be some others that are required for the 4.4 kernel
sudo apt-get build-dep linux-image-$(uname -r)
sudo apt-get install libncurses5-dev
Then the commands I have issued for a sucsessful build are:
chmod a+x debian/scripts/*
chmod a+x debian/scripts/misc/*
nano debian.master/changelog
fakeroot debian/rules clean
fakeroot debian/rules editconfigs
fakeroot debian/rules binary-headers binary-generic skipabis=true
Modifying the changelog file to indicate that I am creating my own kernel, by adding something to the end of the first version number that is shown.
Charles Green
  • 21,859
