50
In Ubuntu 20.04 LTS, I was compiling kernel 5.11.11 after adding a new system call. I also get this with later Ubuntu versions and kernels. During the execution of make command I got this error:
make[1]: *** No rule to make target 'debian/canonical-certs.pem', needed by 'certs/x509_certificate_list'.  Stop.
make: *** [Makefile:1809: certs] Error 2
If someone can help I would really appreciate it, Thank you.
Daniel T
  • 5,339
In your kernel configuration file you will find this line:
CONFIG_SYSTEM_TRUSTED_KEYS="debian/canonical-certs.pem"
Change it to this:
CONFIG_SYSTEM_TRUSTED_KEYS=""
Depending on your source structure you might be able to do it via command line. Examples:
scripts/config --disable SYSTEM_TRUSTED_KEYS
or
scripts/config --set-str SYSTEM_TRUSTED_KEYS ""
EDIT: Another key has been added to the default Canonical kernel configuration since this answer was posted:
CONFIG_SYSTEM_REVOCATION_KEYS="debian/canonical-revoked-certs.pem"
So, it also needs to be dealt with for user kernel compiles to complete:
scripts/config --disable SYSTEM_REVOCATION_KEYS
See also git based mainline kernel compile notes.
Doug Smythies
  • 16,146
12
Well, I just generated a self-signed x509 certificate with a common name as my name, put the key and certificate in the same file and pointed both lines to the file. Compiles perfectly and security should be intact. I assume it's used to sign kernel binary and you can whitelist your certificate in a secure boot to allow your kernel to boot.
openssl req -x509 -newkey rsa:4096 -keyout certs/mycert.pem -out certs/mycert.pem -nodes -days 3650
CONFIG_MODULE_SIG_KEY="certs/mycert.pem"
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS="certs/mycert.pem"
CONFIG_SYSTEM_EXTRA_CERTIFICATE=y
CONFIG_SYSTEM_EXTRA_CERTIFICATE_SIZE=4096
CONFIG_SECONDARY_TRUSTED_KEYRING=y
CONFIG_SYSTEM_BLACKLIST_KEYRING=y
CONFIG_SYSTEM_BLACKLIST_HASH_LIST=""
Error404
  • 8,278
  • 35
  • 60
11
Just executed following two commands in after running "make menuconfig"
while "make" command is running, if any certificate related question arises, then simply hit Enter. That's it.
Here is a solution that doesn't require you to disable security :) From your linux directory (e.g. /opt/linux-5.13.4):
  1. mkdir debian result -> /opt/linux-5.13.4/debian
  2. cd certs result -> /opt/linux-5.13.4/certs
  3. cp canonical.pem ../debian* result -> /opt/linux-5.13.4/debian/canonical*.pem
  4. cd .. result -> /opt/linux-5.13.4
  5. make
