I am interested in compiling a custom kernel in Ubuntu 20.04 so I can use the fingerprint scanner in my hp envy x360. Also I want to learn how to learn the process. Where do I start? How difficult is it? Any pointers and/or advice would be greatly appreciated.
Asked
Active
Viewed 1,070 times
From memory:
Log in as root.
Download the kernel sources from kernel.org and uncompress them to
/usr/src/.Open a shell in the directory you just unpacked and run:
make oldconfig && \ make xconfig && \ make && \ make modules && \ make install && \ make modules_installEdit your grub configuration and reboot.
If you're not running X then change make xconfig to make menuconfig or make config.
If you want things to go a bit quicker, change make to make -j4 to run 4 tasks in parallel (change 4 to the number of cores your machine has). The same applies to the make modules command.
Alex Hajnal
- 143
