I started out on Ubuntu 20.04
I wasn't able to install the wireless network card driver (for both Wifi and Bluetooth).
sudo lshw -C network
Output:
*-network UNCLAIMED
description: Network controller
product: MEDIATEK Corp.
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:2d:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm cap_list
configuration: latency=0
resources: iomemory:610-60f iomemory:610-60f iomemory:610-60f memory:612c100000-612c1fffff memory:612c200000-612c203fff memory:612c204000-612c204fff
Command: rfkill list all
Output
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Command: sudo lspci
0000:2d:00.0 Network controller: MEDIATEK Corp. Device 7961
0000:2e:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Command sudo lsusb
Output:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 322e:202c Sonix Technology Co., Ltd. USB2.0 HD UVC WebCam
Bus 003 Device 002: ID 0b05:1910 ASUSTek Computer, Inc. TUF GAMING M3
Bus 003 Device 004: ID 13d3:3563 IMC Networks Wireless_Device
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I've installed Ubuntu 21.04 and upgrading my kernel to 5.12. I installed the network driver and I have got the wifi to work somewhat (randomly sometimes it works and sometimes it doesn't) but the Bluetooth still doesn't work.
I've tried to install kernel version 5.15 following this article, but after I finish downloading the kernel and I run the command sudo dpkg -i *.deb I get this error:
Selecting previously unselected package linux-headers-5.15.0-051500rc3.
(Reading database ... 202480 files and directories currently installed.)
Preparing to unpack linux-headers-5.15.0-051500rc3_5.15.0-051500rc3.202109262230_all.deb ...
Unpacking linux-headers-5.15.0-051500rc3 (5.15.0-051500rc3.202109262230) ...
Selecting previously unselected package linux-headers-5.15.0-051500rc3-generic.
Preparing to unpack linux-headers-5.15.0-051500rc3-generic_5.15.0-051500rc3.202109262230_amd64.deb ...
Unpacking linux-headers-5.15.0-051500rc3-generic (5.15.0-051500rc3.202109262230) ...
Selecting previously unselected package linux-image-unsigned-5.15.0-051500rc3-generic.
Preparing to unpack linux-image-unsigned-5.15.0-051500rc3-generic_5.15.0-051500rc3.202109262230_amd64.deb ...
Unpacking linux-image-unsigned-5.15.0-051500rc3-generic (5.15.0-051500rc3.202109262230) ...
Selecting previously unselected package linux-modules-5.15.0-051500rc3-generic.
Preparing to unpack linux-modules-5.15.0-051500rc3-generic_5.15.0-051500rc3.202109262230_amd64.deb ...
Unpacking linux-modules-5.15.0-051500rc3-generic (5.15.0-051500rc3.202109262230) ...
Setting up linux-headers-5.15.0-051500rc3 (5.15.0-051500rc3.202109262230) ...
dpkg: dependency problems prevent configuration of linux-headers-5.15.0-051500rc3-generic:
linux-headers-5.15.0-051500rc3-generic depends on libc6 (>= 2.34); however:
Version of libc6:amd64 on system is 2.33-0ubuntu5.
dpkg: error processing package linux-headers-5.15.0-051500rc3-generic (--install):
dependency problems - leaving unconfigured
Setting up linux-image-unsigned-5.15.0-051500rc3-generic (5.15.0-051500rc3.202109262230) ...
I: /boot/vmlinuz.old is now a symlink to vmlinuz-5.11.0-37-generic
I: /boot/initrd.img.old is now a symlink to initrd.img-5.11.0-37-generic
I: /boot/vmlinuz is now a symlink to vmlinuz-5.15.0-051500rc3-generic
I: /boot/initrd.img is now a symlink to initrd.img-5.15.0-051500rc3-generic
Setting up linux-modules-5.15.0-051500rc3-generic (5.15.0-051500rc3.202109262230) ...
Processing triggers for linux-image-unsigned-5.15.0-051500rc3-generic (5.15.0-051500rc3.202109262230) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.15.0-051500rc3-generic
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file /etc/default/grub' Sourcing file/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.15.0-051500rc3-generic
Found initrd image: /boot/initrd.img-5.15.0-051500rc3-generic
Found linux image: /boot/vmlinuz-5.11.0-37-generic
Found initrd image: /boot/initrd.img-5.11.0-37-generic
Found linux image: /boot/vmlinuz-5.11.0-16-generic
Found initrd image: /boot/initrd.img-5.11.0-16-generic
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings
done
How can I get this wireless card to work properly?
