I've recently updated to Ubuntu 22.04 LTS and saw there was power options. However, performance mode is not available.
I can't get the same performance and benchmark scores I get in Windows dual boot. I think this is the reason.
So I checked power governor and it says acpi-cpufreq. I checked my grub cfg, and it says intel_pstate=enable. I had the same problem with Ubuntu 20.04, thought maybe it's an issue with kernle, but even with new kernel, it's still not working.
[ 0.062414] Kernel command line: BOOT_IMAGE=/vmlinuz-5.15.0-47-generic root=UUID=9103868b-6caf-4c46-95b9-05f6bb5b8e94 ro intel_pstate=enable quiet splash vt.handoff=7
[ 0.453038] intel_pstate: CPU model not supported
$ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_driver
acpi-cpufreq
$ uname -r
5.15.0-47-generic
$ grep -i pstate /boot/config-$(uname -r)
CONFIG_X86_INTEL_PSTATE=y
$ grep intel_pstate /boot/grub/grub.cfg
linux /vmlinuz-5.15.0-47-generic root=UUID=xxxxx ro intel_pstate=enable quiet splash $vt_handoff
$ cat /sys/devices/system/cpu/cpufreq/boost
$ ls /sys/devices/system/cpu/intel_pstate/
no such file or directory
$ cpufreq-info
..snip..
analyzing CPU 15:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 15
CPUs which need to have their frequency coordinated by software: 15
maximum transition latency: 10.0 us.
hardware limits: 800 MHz - 2.30 GHz
available frequency steps: 2.30 GHz, 2.30 GHz, 2.20 GHz, 2.10 GHz, 2.00 GHz, 1.90 GHz, 1.80 GHz, 1.70 GHz, 1.50 GHz, 1.40 GHz, 1.30 GHz, 1.20 GHz, 1.10 GHz, 1000 MHz, 900 MHz, 800 MHz
available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
current policy: frequency should be within 800 MHz and 2.30 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency is 997 MHz.
cpufreq stats: 2.30 GHz:1,62%, 2.30 GHz:0,13%, 2.20 GHz:0,25%, 2.10 GHz:0,17%, 2.00 GHz:0,27%, 1.90 GHz:0,31%, 1.80 GHz:0,29%, 1.70 GHz:0,54%, 1.50 GHz:0,73%, 1.40 GHz:0,72%, 1.30 GHz:0,96%, 1.20 GHz:1,33%, 1.10 GHz:3,17%, 1000 MHz:6,38%, 900 MHz:18,62%, 800 MHz:64,50% (30660)
$ lscpu
..snip..
Model name: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
CPU family: 6
Model: 141
..snip..
Frequency boost: enabled
CPU max MHz: 2301,0000
CPU min MHz: 800,0000
BogoMIPS: 4608.00
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mc
a cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss
ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art
arch_perfmon pebs bts rep_good nopl xtopology nonstop_
tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes6
4 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr p
dcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline
_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefe
tch cpuid_fault epb cat_l2 invpcid_single cdp_l2 ssbd i
brs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriori
ty ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep b
mi2 erms invpcid rdt_a avx512f avx512dq rdseed adx smap
avx512ifma clflushopt clwb intel_pt avx512cd sha_ni av
x512bw avx512vl xsaveopt xsavec xgetbv1 xsaves split_lo
ck_detect dtherm ida arat pln pts avx512vbmi umip pku o
spke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx5
12_bitalg avx512_vpopcntdq rdpid movdiri movdir64b fsrm
avx512_vp2intersect md_clear flush_l1d arch_capabiliti
es
Also, when I Google the cpu model and intel_pstate, I can see some forum posts with the same cpu, and driver/governor(?) as intel_pstate, so it's probably supported.
I was wondering what steps I could take to further troubleshoot or fix this issue? Thanks!
p.s. my device is a laptop
